Toshiba 37RV530U No power
  • Jim1590
    • Jul 2013
    • 98
    This is one of seven TV's I got off of a guy who had a great idea of fixing busted sets then realized he did not know where to start. Only paid $30 for all of them and one had a decent wall mount, so figure I am not losing out on much. Need power cords on 2 more, 1 is a gutted 55" Samsung , and the other 3 will get their own threads.
    This TV does not power on. Do not see any obvious bad caps. Volts appear good going to the main board (all around 23-23.5 volts on line marked 24) and volts going to backlight is at 2.2volts when marked 12 volts. The set is powered on, I have a green light on the main board and the digital sound port is glowing red.
    Only replacement boards I was able to find are in the UK, not sure if I want to drop 70-75 on a board when the TV ain't worth it. But if I can fix a component on the board itself... that would be great.
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Toshiba 37RV530U No power
    Pics of boards and chassis
    • Jim1590
      • Jul 2013
      • 98
      on the way
      • Jim1590
        • Jul 2013
        • 98
        http://www.2shared.com/photo/qGk891Q...ba_chasis.html
        http://www.2shared.com/photo/7LLwUCXk/toshiba_main.html
        http://www.2shared.com/photo/MNeXEe4...ower_back.html
        http://www.2shared.com/photo/TtwY5yO...nnections.html
        http://www.2shared.com/photo/ZCkd8LC...wer_front.html
        http://www.2shared.com/photo/IUGBGVs...ba_power2.html
        • newtothis
          • Mar 2013
          • 1556
          • england
          DO you get any LED lights on the front of the set? Green or Yellow?
          • Jim1590
            • Jul 2013
            • 98
            Just plug in, get 2 sets of 3 flashes yellow lights. Then turns green. Green is solid and turns on and off with power button. The yellow does not repeat until TV is unplugged and plugged back in. I should have checked that first. It should have been right after verifying it is plugged in! Sorry about that and Thank You
            • newtothis
              • Mar 2013
              • 1556
              • england
              the initial flashes of yellow are normal for this set and will do it every time the set loses AC power, It will flash until the remote is usable.
              • Jim1590
                • Jul 2013
                • 98
                ok, so the tv thinks it is working correctly, just no image. or at the least, no blink codes.
                hope you mean flashes until the ability to use a remote is there cause I didn't get the remote with it! lol
                • newtothis
                  • Mar 2013
                  • 1556
                  • england
                  Basically its just as the software is booting up.. after the orange light stops it will turn to solid green which indicates the set is on.
                  • newtothis
                    • Mar 2013
                    • 1556
                    • england
                    I am having problems with my ZEUS install so I cannot look at the schematics properly.. as soon as I get working I will take a look and see if I can help out.
                      There will be a connector with 24V, GND, etc on it. Check the 24V from there.
                      • Jim1590
                        • Jul 2013
                        • 98
                        OK, checked all 3 connections.
                        The top one in the picture(going different direction) and the middle one are values I expected.
                        24 volts expected give me 23.5 actual
                        18 volts expected give me 17.6 actual
                        12 volts expected give me 11.6 actual
                        5 volts expected give me 4.9 actual
                        Power Sig is 3.2
                        The last connector got the following:
                        Power Protect 3.0
                        Power Signal 3.2
                        AC Detect 3.5
                        Stop Fan 1.4
                        Power LCD 3.3
                        Gnd 0
                        Gnd 0
                        12VLCD 2.2
                        12VLCD 2.2
                          Do you see any pin marked "BL ON" or "ON/OFF"?
                          • Jim1590
                            • Jul 2013
                            • 98
                            Here is the pins and readings
                            http://www.2shared.com/photo/1otpLRV4/connections.html
                            • truep
                              • Aug 2010
                              • 373
                              I don't see the inverter. Per cnet it's not an LED, so where is it?
                                Likely mounted on the panel directly, most of these LCD TVs based on LG panels (like this one I believe) came with the inverter attached to the panel.
                                Jim, try tracing the 24VINV/GNDINV to a board. There's probably a separate cable coming off it for the control signals like BL ON/OFF. A common fault on these panels is the inverter going bad. If it uses a xx490 inverter, you can sub in an xx504 inverter (much cheaper and better reliability.)
                                • Jim1590
                                  • Jul 2013
                                  • 98
                                  OK, I will expose the other board it is buried someplace under the main. Will post back once I get to it.
                                  • Jim1590
                                    • Jul 2013
                                    • 98
                                    http://www.2shared.com/photo/5r0r1tG...ght_board.html
                                    http://www.2shared.com/photo/U3PUoD3...connector.html
                                    The board itself looks pretty beat up....
                                      This TV has been messed with. One cap on the inverter has been removed. From memory they are 680u/35V. Replace both using Panasonic FC/FM/FR from Digikey or other sources. (RadioShack NOT suitable!!) Check the fuse, too.
                                      • Jim1590
                                        • Jul 2013
                                        • 98
                                        I have a high quality shop next town over that I can get these from. Can you please point me to the fuse and where should other cap be? I will start looking myself, but maps are nice!
                                        I have no doubt the TV was messed with by someone who either did not know what to do, winged it, or didn't know when to ask for help. But I only spent $4.28 for the set (got 7 for $30) so I didn't care all that much!
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • ju123
                                          Toshiba Satellite C50-A won't power down
                                          by ju123
                                          Hi guys,
                                          So, I've been racking my brains on this one.
                                          I have a Satellite C50-A which I'm repairing for a friend.
                                          I recently replaced the main board due to failure.
                                          Following this, absolutely everything works perfectly, except for the fact it won't power down.
                                          Initially, shutting down via Windows would shut the OS down, screen would turn off (noticed the lighter black go to what looks like the darker black powered off screen as though the backlights have powered off), however the laptop was still running internally with a spinning...
                                          01-07-2022, 04:40 PM
                                        • robgerr
                                          Toshiba L50-B-1Q0 (Main DABLIDMB8E0 REV:E) no power on
                                          by robgerr
                                          Good morning forum. This laptop comes into my laboratory with the defect that it won't turn on. By connecting the bench power supply I have an absorption of 1.56A (battery charging), I disconnect the battery, I have an absorption of 0.01A. I give the power on but it doesn't react. I check the mainboard and I notice the Isl88732 charger with oxide and a little burnt between pins 7-8. I remove the charger, clean the pads and solder another ISL coming from another identical board. I also find a bit of oxide in the power button connector. I clean the connector, clean the flat that goes to the power...
                                          12-07-2023, 06:22 AM
                                          09-06-2024, 05:59 AM
