p50hdtv10a flickering with sound with Y-sus ticking
  • DLinkOZ
    • May 2013
    • 238
    I was poking around other threads about this TV flickering, but most had no sound. Then a comment was posted, asking if it had sound and a ticking of the Y-sus that coincides with the flickering. Mine does, so I kept reading hoping for some good input. The thread went sideways and that question was never addressed.
    So I ask - being new to this TV, can someone point me to some troubleshooting steps for the following scenario:
    1. TV has sound from input device (connected to my DVR)
    2. Screen flickers, though it seems as though it tries to make a picture during those brief instances when you're on the light side of the flicker versus the dark
    3. The Y-sus has a corresponding ticket
  • Glitcher
    • Mar 2013
    • 673
    • USa
    Re: p50hdtv10a flickering with sound with Y-sus ticking
    Common problem with this panel flickering is a Bad Y-sus, usually one of the two IPMs have failed.
    • zdsh07p9
      • Nov 2013
      • 155
      I believe your problem is the Ysus,
      have you read this thread? https://www.badcaps.net/forum/showthread.php?t=18495
      Coppell TV repair has a few repair options as well. I have had good experiences with Mr. Kolev at Coppell
      • zdsh07p9
        • Nov 2013
        • 155
        Glitcher beat me to it
        • DLinkOZ
          • May 2013
          • 238
          I did read that thread, but the OP stated no sound so I wasn't sure I was looking at the same thing. I'll Coppell up for a repair, they're a quick 15 minute drive from my house. Just wanted a little sanity check that I was looking in the right direction. Thanks!
          • zdsh07p9
            • Nov 2013
            • 155
            ...its been a long day, how do I delete this post? You should be good with the YSUS repair, if not come back and post it up!
            • DLinkOZ
              • May 2013
              • 238
              Also, I while it's flickering I see the large vertical white bar in the center. Am I correct in assuming that one of the buffers is also bad? Reading through Coppell's blog entry about testing them now.
              • zdsh07p9
                • Nov 2013
                • 155
                https://www.badcaps.net/forum/showthread.php?t=31794
                This is where glitcher replied about the white bar I believe, which as your post states is related to the bad buffer board
                • DLinkOZ
                  • May 2013
                  • 238
                  Using Coppell TV's blog, I tested the buffer boards and it seems as though the lower one is faulty. So I'll get the y-sus repaired and some replacement FETs and hopefully call it done.
                  • DLinkOZ
                    • May 2013
                    • 238
                    Time to dig up an old thread - new y-sus and buffer boards had this guy going really well, just light use in a spare room. Until now, it seems to have a power supply failure this time. When I power it on, it tries to cycle up and clicks a few times on and off, on and off, then finally gives up. Checking things out, it's blowing a fuse on the y-sus board. Further checking shows that some of the 5v (not 5vsb) is shorted to ground. I completely isolated the power supply, and the short is happening there.
                    So my question is - does this seem right? No other voltages exhibit this short, and not the 5vsb. I find it in two different places, see pics. One is labeled 5vsc and the other is 5vctrl. Could it be as simple as a power supply? Nothing obviously bad on the board, but if there's anything I can test on it then I'm game. And as always, I appreciate the assistance I always get here!
                    • DLinkOZ
                      • May 2013
                      • 238
                      I should note that in the second picture, the 5vsc is actually on the connector you can barely see at the right. The connector completely in frame isn't actually used.
                      • DLinkOZ
                        • May 2013
                        • 238
                        A quick update - all 5v, except for 5vsb, is shorted to ground. So is there any non-common point in the 5v rail that differentiates between standard 5v and the standby 5v?
                        • DLinkOZ
                          • May 2013
                          • 238
                          Pictures of the power supply, in case it helps. Some overall, beginning at the upper left and going clockwise to the lower left.
                          • DLinkOZ
                            • May 2013
                            • 238
                            I started tracing back the 5v line from one of the connectors. It's short all the way back to the smaller of the large transformers, T401 (center of the board). All pins on that side of the transformer have continuity, however it could be bleeding back from some other short (failed, cap, etc). Are there any obvious things to check in this circuit? As stated earlier, 5vsb is fine, but all other 5v is shorted to ground.
                            • ChaosLegionnaire
                              by ChaosLegionnaire
                              09-13-2022, 09:02 AM
                            • Solvik
                              XFX XPS 650w 3XS PSU making Ticking/clicking sound
                              by Solvik
                              Hello
                              i have a older powersupply from XFX that makes this wierd electronic ticking /clicking noise. Its not the fan thats making the sound. See video below. Is anyone familiar with what component this sound can come from?
                              All voltages are normal....
                              02-13-2025, 02:43 PM
                            • LEECH666
                              Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                              by LEECH666
                              Good day ladies and gentleman!
                              I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                              This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                              I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                              01-19-2024, 05:46 PM
                            • PlasMatt
                              LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                              by PlasMatt
                              I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                              09-20-2025, 06:50 PM
                            • Christos Tsiligiannis
                              Marian Trace Alpha sound card repair help
                              by Christos Tsiligiannis
                              Hello to the forum.
                              My name is Christos, I am new to the forum here and i am posting from Greece.
                              So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                              To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                              So i tried asking for a schematic from the company and they would not give me one. Instead they...
                              11-18-2024, 05:26 AM
