Toshiba 32DT2U1 Power Supply or Mainboard Issue?
  • s2h
    • Nov 2013
    • 7
    I have a 32" Toshiba LCD that is just out of warranty. When I press the power button on the TV, the green LED comes on for 5 seconds (no picture) and then goes off. I opened the back of the unit and disconnected the mainboard and LCD from the power supply (PK101V1500I). I applied power and measured the output on the connector that faces the mainboard. I could only see 5V on the 5V pins. The 12V and 24V pins had no voltage. Is this normal? I did a quick check of the caps and could not see any bulging. Can I assume the lack of a reading for 12V and 24V is a power supply issue or is the mainboard required to "turn on" these levels.
    Thanks in advance
    Re: Toshiba 32DT2U1 Power Supply or Mainboard Issue?
    The 12v/24v power supply section is switched on by the PWON (PS_ON) signal from the main board when power switch is activated.
    Post good clear pictures of the back of the TV and the boards so we can see what we are dealing with.
    Are these the boards in the version of your TV?
    http://www.shopjimmy.com/catalogsear...oshiba+32dt2u1
    • s2h
      • Nov 2013
      • 7
      Yes those are the boards list on the website. They match what I have below.
      Here are some photos. Turns out my phone camera is not the greatest. I can take some more.
      • randtek
        • Oct 2011
        • 280
        • US
        A corrupted EEPROM causes this problem. I have fixed a few hundred of this model for this issue.
        • s2h
          • Nov 2013
          • 7
          Thanks for the quick reply. Is this something I can fix myself or do I have to take it to a repair shop?
          Better yet is it even worth repairing considering you have seen a few hundred with this problem?
          • randtek
            • Oct 2011
            • 280
            • US
            If you can find a shop that can replace just the EEPROM, it can be done pretty cheaply. Replacing the board is more expensive, but is also a reliable repair, as the weak EEPROM that fails has been upgraded on new boards. Once the EEPROM is replaced, they seem to be pretty reliable TVs.
            • Tvbob
              tvbob
              • 204
              shopjixxy.com has the eprom.
              • s2h
                • Nov 2013
                • 7
                Haven't touched the TV in weeks (other than removing the back to take photos) and decided to plug it in. The picture came on and it worked! Used it for awhile. Next day back to the same symptoms (power light on for a 2-3s and then off). Would a corrupt EEPROM exhibit this behavior?
                • triplefour
                  • May 2014
                  • 1747
                  what ever happened with this one?
                  Don't fear the repair...
                  • s2h
                    • Nov 2013
                    • 7
                    When I first created this thread, I looked for parts at the link suggested. They were out-of-stock so I stored the TV away. Forgot about it until last week. Plugged it in and the set is working fine. We will see how long it lasts. Appreciate the help.
                    • triplefour
                      • May 2014
                      • 1747
                      lol the tv that fixes itself after being in storage is a classic. hope it lasts!
                      • s2h
                        • Nov 2013
                        • 7
                        Lasted 6 weeks and is totally dead now. Just waiting for Black Friday at this point in the game.
                        Cheers
                        • Jembang
                          coocaa 50S5G smart tv dropped voltage when connecting power supply to mainboard
                          by Jembang
                          good day hoping someone can lend a hand, im repairing smart tv 50 inch, status when turning on back light is dim but you can see the tv logo then slowly fading out to black, i check the supply to tcon, i only read 5+v, must be 12v, i removed lvds cable and check voltage to mainboard turned on its also 5v, then i remove the cable mainboard to power supply, i read 12v in power supply, thinking that the problem is in the mainboard, coz theres 12v in power supply, i also check while turning on checking volts in main board 12v dropping to 5v, im just new repairing in TV, hope someone see my post t...
                          11-01-2024, 09:55 AM
                        • Soulzink
                          Samsug washing machine. Power supply DC41-00189a board issue
                          by Soulzink
                          I am trying to fix a samsung washinmachine power supply main board.
                          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                          The power supply board reference is the following: DC41-00189a
                          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                          04-19-2025, 06:26 AM
                        • semiRocket
                          Toshiba 37bv701b power supply main rails
                          by semiRocket
                          The set is not turning on, when buttons on the front are pressed the button press sound is coming from the speakers, but the set is not trying to turn on, consuming only couple of watts.
                          I am troubleshooting a Vestel 17PW26-5 from the set. Not sure how it is supposed to turn on main supply, but with the main board disconnected not getting the main supply to turn on either.
                          Standby supply is working, PFC is working (390V), but the main supply is dead. Checked the mosfets and driving transistors and found they are not shorted and showing a diode junction. The suspicious...
                          10-26-2025, 01:55 AM
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                          09-06-2024, 05:27 AM
