Apex ld3288m - No power, nothing
+ More Options
Posts
  • DLinkOZ
    • May 2013
    • 238
    Re: Apex ld3288m - No power, nothing
    5V traces run two different directions - one trace on the component side and one on the solder side. I can't differentiate which is which coming out from under the connector on the component side. On the solder side, it runs to a via to pop back onto the component side. It then runs into a SMD diode. It's the same strained 2.9v entering, but comes out at 2.2v. It then runs to a very small SMD cap with no voltage on the far side. The diode reads open in both directions, though that's in-circuit so probably isn't reliable. Nothing is running hot after 30 minutes. Or even warm.
      I would do the current draw check using the meter, you will have to cut the wire and put the meter in series with the wire to check the current draw.
      • DLinkOZ
        • May 2013
        • 238
        I'll do that next. No need to cut the wire, I was able to push the lock in to remove both 5V wires from the connector earlier, so I'll do that again.
        • DLinkOZ
          • May 2013
          • 238
          Putting my meter in-line with one of the two 5V lines (there are two in the connector, but they are common - my assumption is they doubled-up for safety and/or current requirements) and leave the other disconnected, I get .47 amps. That should be roughly equal to the 10 ohm resistor test, which did not bring the 5V supply down.
            "my assumption is they doubled-up for safety and/or current requirements" May be or may be not, should verify.
            • DLinkOZ
              • May 2013
              • 238
              I did try both lines, one at a time, and got the same .47 amps. I cannot test both simultaneously as I only have one meter.
                Since both wires are connected to the same 5V power source, you can tie the two wires together.
                • DLinkOZ
                  • May 2013
                  • 238
                  Strapping them together yields the same results @ .47 amps.
                  • DLinkOZ
                    • May 2013
                    • 238
                    I also probed the temp of any sizable part - nothing above ambient room temp.
                      Boy, this is strange. Do you have any 5V wallwart switching power supply that you can use to power this 5V line?
                      • DLinkOZ
                        • May 2013
                        • 238
                        I can look, but it's doubtful. What about the 5V rail of a PC power supply? If that will work, how do I handle the ground?
                          That will work, just connect the DC output ground of the PC power supply to the chassis, then use 1A fuse for the 5V line. You probably should have dummy load connected to the PC PS, I do not know what the required min load is for your PC PS.
                            When I test a PC PSU I always attach a 3.5" hard disk to one of the connectors, it provides sufficient minimum load. (Around 10 to 15 watts.)
                            • DLinkOZ
                              • May 2013
                              • 238
                              Actually, I forgot I have a 22" monitor with a blown inverter transformer and subsequently fried ccfls. The power supply, however, is solid. So I'll jump its 5V over to this set for testing.
                              • DLinkOZ
                                • May 2013
                                • 238
                                So here's what I found:
                                Ran the 5V of this TV off the 5V output of the 22" monitor's power supply. Current draw was a similar .53 amps. I had a solid 5V at the main board, versus the lower 2.9V of the original power supply. All other symptoms remain (390V across the primary cap, power button shows no sign of life).
                                So it's a head scratcher, for sure. On one hand, the main board did not bring down the 5V line of the other power supply. On the other hand, it still did not pull the primary cap down to 170V.
                                  It seems like the power board does have a problem, but it's right on the limit. Haha, what luck... The standby circuit also powers other parts of the power board, so a fault there can affect other parts. I would try replacing the startup capacitor.
                                    Sure is a tough one, notes to self: cannot be 100% sure using dummy load testing power supply due the the logic circuits do not draw constant current.
                                    Well I am not sure what else I can do, you do have main board problem and also power supply problem. From the way it looks, it has only one transformer where the 5VSTBY is generated, then it may have switched transistors for supplying switched 5V and 12V which are also generated by the same transformer.
                                    • DLinkOZ
                                      • May 2013
                                      • 238
                                      Ok, so here's an oddball question - that primary cap is 82uf @ 450v. I have a 140uf @ 400v, would it be possible to use that for a temporary test? I know the specs are out, but I've seen other references of people using other such variations without issue.
                                        A 450V minimum capacitor is recommended, because the ripple on the PFC can make the capacitor exceed 400V sometimes.
                                        • DLinkOZ
                                          • May 2013
                                          • 238
                                          I used that cap as a 30 second test, just to see what happens. Exact same scenario.
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            09-06-2024, 05:59 AM
                                            HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-12-2024, 02:15 PM
