My TV has just recently started to lose its picture for a split second at random intervals. Say, on average, 6-12 times a minute. The loss only lasts for a fraction of a second - so I guess you could call it flickering? But it makes watching TV next to impossible!
I originally thought that it may be caused by the Rogers NextBox 3 HDPVR - which I just switched over to from Bell. But I have tried every conceivable thing (connecting through the AVR vice direct to the TV / tried the standard def box that I use upstairs on this TV / even hooked Bell back up) to confirm that it was not the NextBox 3 that was at fault - although the timing is suspicious - never had a problem with the TV for 5 years using Bell and now within a month of switching over to Rogers this?
Weird thing is though that if I leave the channel on the On Demand for Rogers the picture is fine and doesn't flicker?
I did replace the Y-Drive recently to correct a loss of picture on the bottom of the TV (about 4" horizontally at the bottom). This went well and the TV was working like new again.
So what do you think can be causing this loss/flickering?
Also, if I have to get a new TV which brand of Plasma would you recommend - I will be getting an extended warranty this time!
Thanks Much.
Thanks Much.
