RCA 42PA30RQ plasma tv problem
    Re: RCA 42PA30RQ plasma tv problem
    X Main shows a short.
    Thanks for everyone's help. I think next time, I will save myself money and time and just send the tv to be recycled from the start.
    We have all Panasonic tvs now, so hopefully won't have premature failures. 18 months is a pretty short life span for a tv, not impressed with this RCA/Samsung for sure.
    You all have a Merry Chrisymas and happy New Year.
      I have a similar problem with my RCA 42PA30RQ. I've read various posts but none of them cover my exact problem. I am also unable to create a new post as I just became a member today..
        Ok whats the issue?
          My VA with everything accept the Y buffer unplugged is staying steady at 120..
            OK I think Tom66 would be best at helping with this...
            Take pics of each board and then one of the entire back of the chassis so we can see everything.
              Here is the pictures..
                If you'd said the opposite was happening, you could probably point to the Y-buffer as being the issue. Otherwise, the Y-main being disconnected pretty much means the Y-buffer is disconnected, too. How does your VS voltage look?
                LG Plasma Mal-Discharge Correction Service
                  Both stay steady over 200 (200 is max on my multimeter). With the Y main plugged in the voltage drops.
                    As far as some other things go, there is a slight screen glow I don't notice any pixels when I hit the menu button, one normal click on and the LED on the control board is on for maybe 5 seconds and off for about 2.
                      Ok, so your issue is a typical one. I'd stop right there and pull both the Y-main and X-main to check the heat sink components for shorts. If you continue to test without pulling boards, you may do more damage.
                        I read something about that but something confused me. I don't remember exactly what is was but I should be testing the resistance? If so what readings should I get?
                          high resistance means no shorts, low resistance means a short
                            Here you go: https://www.badcaps.net/forum/showpo...17&postcount=9
                              Nothing reads a 0.00.
                                as far as "low" resisatnce goes Q5013 only reads 5.76 whereas the other 3 prongs with offset center prongs read a flat 10. I don't know if that makes a difference or not.
                                  Did you follow the steps in the thread I posted?
                                    As far as testing the diodes and transistors yes. I just triple checked. I don't seem to have a short in the X or Y boards.
                                      Something else to try: https://www.badcaps.net/forum/showthread.php?t=26790
                                        Okay, I've located the 4 pin. The only problem so far is they aren't numbered. I'm assuming the pins are from left to right 1/2 then 3/4 on the bottom?
                                          Can you take a close up pic of the 4 pin connector?
