RCA 42PA30RQ plasma tv problem
  • Stude
    • Nov 2013
    • 13
    I have been reading all the threads here pertaining to this model tv, and have done some probing in the tv. Basically I would like you opinions to verify which boards I may need to repair this. I have ordered a Panasonic to replace it but would like to fix this set since the parts seem to be relatively inexpensive.
    It was working fine until one evening my wife turned it on by the manual button and she said the screen lit for a moment and went blank. To my knowledge, there was no sound either, but I can't verify the sound because I am not sure what input it is on since the screen doesn't work.
    The red LED is on, and will turn blue by either using the manual button or by remote. It clicks once (which is normal), and after a couple seconds will click again twice, and nothing happens.
    I printed off one of the threads here which explains the boards and general locations, and explains how to check the boards by unplugging them one at a time. I also checked the Y buffer as is shown in the youtube video within the thread.
    The results are as follows:
    -Unplugged z-sustain only= still clicks 3 times when turned on
    -Unplugged y-sustain AND z-sustain= clicks 1 time when turned on (normal)
    -Unplugged y-sustain only= clicks 1 time when turned on (normal)
    -Disconnected y-buffer from y-sustain only= still clicks 3 times when turned on
    -I checked the voltage with y-sustain unplgged and have 205+- (va) and 54+-(vs)
    -Tested y-buffer and found no continuity (shorts)
    Since I can't weld new compnents on a circuit board with my MIG welder, and my soldering skills leave a lot to be desired, I am relegated to replacing complete board assemblies.
    With the above info, I would suspect at minimum, it needs a y-sustain board.
    So I am looking for your expertise on:
    1) Is there anything else I should check before buying new boards?
    2) What do you recommend I should get for boards?
    I would rather err on the safe side than to install a board and burn it out again.
    Thanks,
    stude
  • Stude
    • Nov 2013
    • 13
    Re: RCA 42PA30RQ plasma tv problem
    After looking at shopjimmy.com, I noticed that one main board requires a firmware update.
    -How do I go about that?
    -Where does one get the updated "firmware"?
    -Does this really stop failures as they are suggesting?
    • Stude
      • Nov 2013
      • 13
      Ok, so I might have found out how to go about downloading the info and installing in the tv. Would I be correct in assuming that I would install the firmware from Samsung on my RCA TV? Most of the boards are Samsung, so I assume that the complete tv is a rebadged Samsung... or is it not?
      • tw2005
        • Oct 2011
        • 6458
        The mainboard is not Samsung so I very much doubt you could upgrade the firmware on it following that guide.
        Could look here, not sure if it will help at all.
        RCA
        I had the Samsung model with these boards, lasted 1200hrs and replaced the X,Y and buffers ( buffers were ok)
        • Stude
          • Nov 2013
          • 13
          RCA
          I looked on the RCA website and they have nothing for my model that I found.
          So, it appears that I should try to find the exact RCA replacements rather than an updated Samsung board that requires a firmaware update?
          I wouldn't want repeated failures... especially since the original only lasted 18 months or so.
          • Stude
            • Nov 2013
            • 13
            Well, I have replaced the x main, y main and y buffer boards, and although it only clicks on once, stll has no picture.
            Any suggestions?
            • freakaftr8
              • Oct 2012
              • 3743
              Are you geting proper voltages to these boards still? Where did you purchase the buffer boards? If from a cracked panel tv I more than sure one or both buffer boards are bad that you purchased. If.so your old buffer boards may be ok if it was just a y sustain failure. Check new buffer boards for shorts.
              • Stude
                • Nov 2013
                • 13
                Voltages are as follows...
                PS connector to Y main:
                VA- 55, then slowly to 0
                VS- 206, then slowly to 0
                15V- 15 steady
                Connector Y main to X main:
                VS-206, then slowly to 0
                VE- 99, steady
                VDD- 5 steady
                Boards came from Retech tv in TN.
                This has a single y buffer, as opposed to an upper and lower. I switched back to the original Y buffer board and no difference.
                I tested the replacement Y buffer, per the video linked on this forum somewhere, and it tested ok, same as the original.
                • capkid
                  • Oct 2010
                  • 1339
                  I'd pull your Y-main and X-main and check a few components on the heat sinks for shorts: https://www.badcaps.net/forum/showth...t=ns-50p650a11
                  LG Plasma Mal-Discharge Correction Service
                  • Stude
                    • Nov 2013
                    • 13
                    I performed the test as instructed by the above linked thread. I found several bad diodes and transistors on both original boards. I checked my replacement boards and the X main tests ok, but there are a couple transistors on the Y main that show continuity, like 1-1.5 ohms.
                    So looks like I need another Y main, eh?
                      I would always advise both the X- and Y-main to be replaced simultaneously on these models, as replacing just one may lead to a "wounded" board damaging the other.
                      • Stude
                        • Nov 2013
                        • 13
                        I found some further testing info for diodes and transistors on youtube, so I need to maybe clarify what I am seeing. I am testing with my meter in diode test mode.
                        I am familiar with diodes as there are several applications of such in the primarily mechanical field in which I have worked. Basically, continuity one way, not the other with an ohm meter.
                        Transistors, not so much... as I understand it, the transisitor would be basically a double diode, with a common leg?
                        With that said, my old Y main and my old X main showed shorted diodes with continuity both ways, and some transistor readings of 0.000 (shorted) as discussed in your link above.
                        Here is where the clarity is needed. When testing the replacement X main, I do not have any readings that show 0.000 between any of the legs of the transistors, and the diode tests ok (OL one way, 3.8XX the other). However, each transistor is not necessarily the same readings as one another.
                        On the X Main, there are 3 transistors with a center protruding leg, and 2 with straight legs. The readings on them are not consistent, not only in regards to ohms readings, but in regards to continuity. The first one tested using the center protruding leg as common, had one way each OL, one way each with a reading of .396, and .921, and then .631, between the outside legs one way, .561 the other. The next one with a center protruding leg reads OL-OL, and OL-.387 using the center leg as common, and from outside legs, .567 one way, OL the other.
                        Bottom line is I have no 0.000 readings on the replacement X main. But I am confused and concerned about the inconsistent readings on the transistors, even on transistors with the same part number. Maybe it is caused by the components being in the board, and therefore attached to other circuits and components?
                        I do have some diodes and transistors on the replacement Y main that read. 0.000, so I assume it is bad. I just want to be sure that the X Main seems ok before I request another replacement Y Main.
                        • Stude
                          • Nov 2013
                          • 13
                          So regardless of tests, I should request all 3 boards again? Y Main, Y buffer and X Main...
                            You can leave the Y-buffer. Only replace X- and Y-main.
                            • capkid
                              • Oct 2010
                              • 1339
                              I personally don't trust the old Y-buffers and the tests performed to verify their states in these thin-profile Samsungs, but they rarely fail. Also, I'd perform the same heat sink component tests on your replacement X-main and Y-main before installing them.
                                Especially given a good number of the Y-buffers are damaged after the screen cracks (which they are pulls from, cracked screen sets.)
                                • Stude
                                  • Nov 2013
                                  • 13
                                  I was finally able to contact Retech Tv and explained the situation, and they are sending another Y Main and Y buffer. I metioned replacing all 3 boards to be safe, but I guess it is their call as the X Main tested maybe ok.
                                  The guy metioned that the panels can short out even though there may not be any visible cracks, although he stated it is on seldom occasion that they see a bad one.
                                  So, I will see what happens, and let you know how it ends up. Hopefully good, because if it doesn't work this time, it is probably headed to the transfer station to get recycled. "Gotta know when to hold em, and when to fold em".
                                  • capkid
                                    • Oct 2010
                                    • 1339
                                    I agree that the panels rarely are at fault in these Samsungs.
                                    • Stude
                                      • Nov 2013
                                      • 13
                                      Update:
                                      Received second Y main and Y buffer from Retech and installed. Checked the transistors and diodes on the Y main before installing. No shorts found. X Main had been checked, no shorts found. Verified all of the plugs and ribbons are seated properly and locked in place. All screws installed in the panels.
                                      Watched the screen as I turned it on the first time. First click on- There were some lines that flashed blue for a second and then two more clicks- nothing. Seems I am back at sqaure one. Three clicks of the relay and no worky. This time I did notice a green LED that slowly flashes on a small panel in behind the output board. Could have been flashing before but I never noticed it.
                                      Removed the Y buffer, and turned on, still clicks 3 times and off. Unplugged the X Main and clicks once and apparently stays on. Appears to be an X Main problem again, but I am not sure of much at this point.
                                      Any suggestions before I call it quits on this and blew a bunch of money for nothing?
                                      • capkid
                                        • Oct 2010
                                        • 1339
                                        Pull your mains and check the transistors and diodes again. I'd probably bag it if you find shorts.
                                        • GRANDGG
                                          LG 42lw4500 flashing red light , wight light , 2 clicks
                                          by GRANDGG
                                          Hi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
                                          05-09-2025, 12:27 PM
                                        • peter99
                                          HP 245 laptop not charging when turned on
                                          by peter99
                                          helo everry body!!!
                                          My laptop HP 245 AMD 14-FP5-6L -GDDR5X2 has a battery charging circuit error:
                                          - If not power on, battery charge ok.
                                          - if i turn on the power, not charging the battery ( the battery charging indicator light, from yellow to white)
                                          The laptop only charges when not turned on. I have changed the battery and charger, but the situation remains unchanged.
                                          I replaced the BQ 25A charging IC but the device only charges when not turned on.
                                          everyone please help me with solution, what should i do ?
                                          thanks a lot !!!!!...
                                          04-04-2025, 07:35 AM
                                        • HonkBeep04
                                          Panasonic TC-P65ST50 plasma in protection mode after incident
                                          by HonkBeep04
                                          Hello everyone! I picked up this 65" ST50 plasma TV for $80 on Facebook marketplace two weeks ago. I have the basic electronic knowledge of a teenage computer geek, having assembled laptops and PCs and messed with soldering and software.
                                          This afternoon I decided to disassemble it to mitigate a buzzing noise. This is a well known issue for this TV ever since they were new. The popular solution is to replace the loose internal screws for ones with lock washers, preventing any future buzzing. I figured that I could just fully loosen and tighten all of the screws securing the...
                                          04-26-2022, 11:04 PM
                                        • ArMaaN376
                                          Samsung PS51E550 Plasma TV
                                          by ArMaaN376
                                          I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                                          Opened TV cover & observed foll
                                          a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                                          b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                                          c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                                          How to confirm Y -Buffer board...
                                          06-19-2024, 04:05 AM
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
