Samsung TV Model LA26R71BA
  • john_doe
    • Apr 2013
    • 192
    • Malaysia
    Re: Samsung TV Model LA26R71BA
    There is no text on screen when those buttons are pressed after the standby mode. After the last button i.e. Power button is pressed, the TV is turned on.
    I hope I get your instructions correctly.
      Maybe it is different for Asia/Pacific TV (="LA") compared to US (="LN") and Europe (="LE"). I will do some quick research.
        According to the service manual found here
        it is POWER OFF -> INFO -> MENU -> MUTE -> POWER ON.
        If that does not work then a different reset technique needs to be tried, but I am not sure it will work on these models.
        • john_doe
          • Apr 2013
          • 192
          • Malaysia
          Hi Tom66,
          It seems to work.
          I pressed INFO->MENU->MUTE->POWER ON and some texts appeared. I selected RESET and the intermittent audio seemed to be gone.
          I will monitor for a few days.
          Thank you Tom66 for your guidance and patience.
            Glad to hear, let us know if it's a permanent fix.
            • john_doe
              • Apr 2013
              • 192
              • Malaysia
              #26
              The intermittent audio is back.
              After I switched off for about 8 hrs, the problem returned when I switch on the TV. Seemed like the factory reset only worked for a while.
              Could it be the caps as the power is discharged after 8 hrs?
                Go back into the service menu and check what the READY is set to. It will be hidden in one of the sub menus.
                • john_doe
                  • Apr 2013
                  • 192
                  • Malaysia
                  #28
                  The Ready from Option Table(Service) is set to ON. It cannot be turned OFF.
                  The TV still has intermittent no audio. Where else should I check?
                    So, out of interest, if you repeat the reset procedure, do you get another ~8hrs? Or perhaps that was just a coincidence?
                    • john_doe
                      • Apr 2013
                      • 192
                      • Malaysia
                      #30
                      Hi Tom,
                      The 8 hrs was the time I left it overnight. I wouldn't know exactly how long it takes to revert back to the intermittent audio problem although.
                      • hijodalgo
                        • Jan 2011
                        • 35
                        #31
                        Main Board problem..if reset did nothing good,change the main Board..
                        • john_doe
                          • Apr 2013
                          • 192
                          • Malaysia
                          #32
                          Hi Tom66,
                          What is your opinion?
                          • john_doe
                            • Apr 2013
                            • 192
                            • Malaysia
                            #33
                            Hi Tom66,
                            • inadim
                              • Oct 2013
                              • 7
                              • uruguay
                              #34
                              Try cleaning the main board with isopropyl alcohol,may be flux.
                              good luck.
                              • cheeky2
                                Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                                by cheeky2
                                This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                                I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                                Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                                06-15-2025, 05:12 AM
                                03-31-2024, 02:12 PM
                              • alltvrepairs
                                Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                                by alltvrepairs
                                I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                                I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                                Any one met this problem in the past?...
                                10-08-2025, 07:34 AM
                              • Tynan Dill
                                by Tynan Dill
                                Assuming...
                                11-22-2024, 01:46 PM
                              • Nicktronic
                                Samsung Power Supply Board BN44-00874F
                                by Nicktronic
                                Hey everyone,
                                This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                                Anybody...
                                03-17-2025, 06:20 AM
