Sony Bravia KDL-46Z4100: Dark in the middle, left side good, right side "freezes."
  • leegee_77
    • Nov 2013
    Brand new member here. My five-year old Bravia KDL-46Z4100 developed a problem last week. While watching it, a black horizontal line in the center third showed up and flickered for a minute. After a bit of time, the lower third center of the screen went dark (like a dark rectangle), then a general dark smear developed top to bottom in the center third of the screen. The left third looks okay, and the right third sort of freezes and holds the image for a bit but never really recovers.
    This lasted for a bit of time that night, and then corrected itself like nothing was wrong. TV ran fine for a couple of nights, then it happened again, same way. The last time it happened, the picture didn't recover and the picture stays as described above. If the scene is well lighted, the center third shows up, just darker with muted and off colors. In dark scenes, the center third is barely visible - just dark.
    I have the back off of the unit. I see all of the major components. I work in the electronics industry, but this is my first foray inside of an LCD TV. All I know about them I learned in the past couple of hours perusing this forum!
    For reference, here's a pic from this forum of a TV identical to mine. Inverter on left (I removed the EMI shield to look around), T-CON at top (I have not poked around there at all).
    https://www.badcaps.net/forum/showth...ny+KDL-46Z4100
    Any thought would be appreciated!
    Thanks,
    Lee
    Last edited by leegee_77; 11-01-2013, 11:50 PM. Reason: Correct model number in title. Added link to picture.
    Re: Sony Bravia KDL-46Z4100: Dark in the middle, left side good, right side "freezes.
    This is most likely a tab bond fault. There are videos on youtube which relate to this problem.
    http://www.youtube.com/watch?v=purk_SyiT44
    ^different problem but same root cause
    • leegee_77
      • Nov 2013
      Hi Tom66,
      Thanks for your reply. I checked around all of the tabs to try to make any changes and had no success. We've pretty much decided to give up on the good old Bravia and get a replacement TV. Probably a Samsung 55". A little disappointed that a five-year old TV has gone, but that's the way of it these days.
      Best wishes,
      Lee
      • RJARRRPCGP
        • Jul 2004
        • 6304
        May have crap caps.
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • Stephen
          A2442 MacBook Pro 14" Two Left SIDE USB C ports charge but no data
          by Stephen
          Right SIDE usb.c port charges and transfers data without issue, two left side uSB c ports charge but do not receive or see data. Was liquid damaged, and repaired significantly and thought we were in the clear but appears this is the last issue that is rearing its head. I am trying to locate the RETIMER chip that communicates the DATA TX/RX but I cannot seem to find it on the schematic or maybe I am just so tired my eyes wore out lol. Any help would be great.
          05-29-2025, 10:35 AM
        • ravi_1617
          HCL Laptop SCREEN SIZE SHRINK LEFT SIDE AROUND 2 INCHES
          by ravi_1617
          Hello to all ,
          I have this HCL ME LAPTOP K 41 ,screen image is shrieked clock /speaker left side approx. 2 inches .Its 14.1 LCD SCREEN. I have replaced lcd screen ,found no difference
          Its blank that area blank and bottom of Task bar is rolled at bottom displaying top portion image . In bios /setup also getting same problem
          on external VGA port image is perfect /normal , Attached image...
          07-25-2025, 12:07 AM
        • Gjackson
          SMEG induction cooker error EA on both left hand side cooktops
          by Gjackson
          I have a SMEG cooktop with a EGO 72.08041.002 power board. The two left hand side cooktops started to slowly fail, sometimes stopping with an EA error (Power board failure according to the manual) after a couple minutes boiling some water and eventually they completely failed and now get an EA error on both of them at all times. Visual inspection of the board went over ok, I checked the IGBT's and rectifiers and they seem fine, what should I look at next as this is the first time I'm fixing an induction cooker, I'm suspecting capacitors in this case, Which ones should I look...
          07-09-2024, 01:46 PM
        • valvashon
          Samsung UN60JU6500, stripe on left side of screen
          by valvashon
          Friend sent me this picture of what their 60" Samsung from 2015 is doing. I didn't have any luck getting rid of a vertical stripe in another TV that developed one so I'm not too excited about trying to fix this one. It's mine for the asking; wish it had a dead power supply or bad backlights instead.
          Is this most likely to be a connection at the circuit board or where the ribbon cable hits the screen itself?
          Update: was just informed that this stripe comes and goes and has been doing this for a couple of months.
          Thanks, Val
          11-21-2025, 03:01 PM
        • howardc64
          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
          by howardc64
          • Prior owner tried a replacement main board. No difference.
          • Samsung 2x red blinking standby LED = panel fault
          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
          07-19-2025, 10:54 PM
