What causes PDP failure?
  • Skipfinder
    • Oct 2013
    • 19
    Besides the obvious cracked screen, what causes a plasma display panel to fail?
    And yes, I'm curious about failure modes of the panel itself.
    Re: What causes PDP failure?
    There are address drivers bonded along the bottom of the panel: these drive the data onto the panel. When they fail you get stuck lines/blocks. Not repairable. I'd estimate around 90% of panel failures due to this.
    There are scan ribbons along one side of the panel: these can de-laminate (extremely common on 2009 and 2010 Samsung sets) causing horizontal lines to appear. Not repairable. I'd estimate <5% of panel failures due to this.
    You can get a short between the scan and sustain electrodes, causing the buffer/drive board to fail (extremely common on 2007 Panasonic 1080p plasmas.) Believed not repairable, though I think it may be possible to "blow out" a short, I have not yet tried this theory. I'd estimate <3% of panel failures due to this.
    You can get maldischarge due to ion implant damage in the panel. Causing a permanent misdifussion or sparklies which clear after warming up. (Extremely common on LG 2005~2008 plasmas.) Somewhat repairable, but never completely. I'd estimate <2% of panel failures due to this.
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • howardc64
      Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
      by howardc64
      Eventually discovered a burn mark near lower corner of LCD. Here is a summary
      • Backlight on, no image
      • Disconnect right buffer board (view from front), left side display comes on
      • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
      • Buffer board is pretty simple
      Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
      07-11-2025, 04:04 PM
    • x_orange90_x
      Busted panel corners... Repairable?
      by x_orange90_x
      I have a 50" Toshiba bezel-less that I replaced backlights in a few weeks ago. The tape didn't hold well so the panel started hanging from the top. The pressure caused the two bottom corners to shear off. I can see a court contact on the right corner, but the left is gone in assuming. The screen is not cracked anywhere else, but it displays no image.
      Is it at all repairable? I'm assuming not....
      02-02-2025, 04:17 PM
    • npielawski
      MacBook Pro late 2016 (820-00239) with multiple failure modes.
      by npielawski
      I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
      I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
      10-15-2025, 01:53 AM
    • howardc64
      LG 49UJ6500 LCD panel lighter band that goes away
      by howardc64
      49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
      Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
      02-19-2023, 12:13 AM
