I have a Panasonic viera 50" TC-P50S1 with TNPA 4782AB SC board. It is bad and i need another one. I see no boards cheap for this one, i do see a sc board for a TC-P42S1 or 46S1 . Shop jimmy website doesnt look like they cross does anyone know anything about this SC board swapping.
Any board substitute for sc board TNPA4782 in Panasonic Vier 50"
Tags: None
Re: Any board substitute for sc board TNPA4782 in Panasonic Vier 50"
This is the problem now as the boards run out, someone has to repair them so cheap boards are pretty much extinct and even a broken board has some value.
A 50G15 SC I suspect would also work, maybe some minor capacitor differences but I have not compared the G10/G15 to see.
Somone found this one but he's put the wrong part number in the listing so I would confirm what is for sale. Again it's rev AF but as cheap as your going to get so long as it is ok and not damaged as it's from a broken screen TV in use.
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by canadaboy25I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
- Loading...
