Samsung LN32C540F2D will not power up
  • mrb3715
    • Oct 2013
    • 9
    I have a Samsung LN32C540F2D, Ver CN05, that will not power up. I was watching it a few days ago and it shut off like i hit the power button. The red standby light is illuminated. I visually inspected the power supply board, and main board, and found nothing interesting. All of the caps looked good, no bulging, leakage, etc. I checked the P_ON line for the 5V feedback from the main board and it was at 0 volts. I kept my meter on that pin at the power supply and touched the power button on the face of the TV. The P_ON input to the power supply board jumped to 1.35 volts for a couple of seconds then went right back down to 0 volts. This happens every time i hit the power button. The main board is part number BN96-16368A V2004.1. The power supply board is part number BN44-00338B and the date on it is in 2010 if that matters. Thanks for any help!!
    Re: Samsung LN32C540F2D will not power up
    Try disconnecting the LVDS cable between the main board and the T-CON board to see if it will power on OK.
    Also post good clear pictures of the back of the TV and the boards so we can see what we are dealing with.
    • mrb3715
      • Oct 2013
      • 9
      I believe I disconnected the cable you suggested and still no change. To be sure i disconnected the correct cable I have attached a picture of it as well. Here are pictures of the main and PS boards. Thanks!
      • mrb3715
        • Oct 2013
        • 9
        After doing a little more research I think that the T-CON is part of the main board in this model. The only other board on the back of the TV other than the ones in the pictures is the high voltage board.
        • martino
          Not so "senior"
          • Aug 2013
          • 997
          • canada
          you need to read this thread >>>>>>>>>>>
          https://www.badcaps.net/forum/showthread.php?t=30259
          Proud owner of dozens of broken TV's and many,many,many boards.
          Our website and passion:http://hollenhundshepherds.com/
          • mrb3715
            • Oct 2013
            • 9
            WOW! That sounds pretty familiar. I will try jumpering the 5V stby pin to the P_ON pin and see what voltage I have being output by the PS. If the power supply works as it should with the 5V applied to the P_ON pin, is it then logical to say that the main board is faulty since it is not providing the 5V to P_ON itself? Thanks!
              Ah, I forgot about that thread. Make sure not to have the cable connected between the main board and the power supply board, otherwise the PS_ON will be kept low by the main board.
              • martino
                Not so "senior"
                • Aug 2013
                • 997
                • canada
                I remember it cause I have the same tv with the same problem. You will find when you power up the psu with the jumper, that the voltages will act like in that thread. Very common on those boards.
                Parts can be bought on eBay. Just eBay search your board number
                • martino
                  Not so "senior"
                  • Aug 2013
                  • 997
                  • canada
                  http://www.ebay.ca/itm/SAMSUNG-LN32C...item2c73b563cf
                  There ya go
                    By the way, this is the SCH of the BN44-00338B (provided by TOM66) so you can see the suspected IC and the cap, but we will wait until you do the force on first.
                    • mrb3715
                      • Oct 2013
                      • 9
                      I will try this as soon as I get home and report back, thanks for the help!
                      • mrb3715
                        • Oct 2013
                        • 9
                        Well it took me a little while, but after taking the readings at the power supply they seemed odd like in the string you posted for me earlier. I purchased the chip and capacitor and replaced them today but it didnt work, still standby light on, but no power on, any more ideas? Now however I have no output from the power supply board at all. I triple checked my solder joints and all, everything looks great. wondering if i got a DOA chip?? Thanks!
                        • martino
                          Not so "senior"
                          • Aug 2013
                          • 997
                          • canada
                          Did you try a force on after replacing the parts?
                          Is there by chance a insulator between the chip and the cooling block that didnt get installed?
                          • mrb3715
                            • Oct 2013
                            • 9
                            I did do the force on, but still no outputs other than the 5v for the stby light. there was no insulator between the chip and the heatsink. there was a bit of thermal compound so i put some on the new chip but that was it. I looked over my work several times but am at a loss. Budm, for some reson i am not able to open the schematic you posted, is it possible to email it to me?
                            • martino
                              Not so "senior"
                              • Aug 2013
                              • 997
                              • canada
                              Only 5volt standby, no other voltage at all?
                              Wonder if there's something a miss with how you do the force on.
                              Could you explain how you do that? Or a pic would be even better.
                                You can directly download the SCH here:
                                http://www.tgohome.com/ServiceManuals/
                                • mrb3715
                                  • Oct 2013
                                  • 9
                                  Thank you for the link! Martino, i had 5V on pin 16 of the power supply output connector and I jumpered it to pin 18 which was indicated to be the PS_ON pin. I have a bit of new info. The leftmost pin of the IC801 that I replaced is fluctuating between 140V and 280V. The rightmost two pins fluctuate between -3V and approx 15V. The fluctuations are simultaneous from input and output. Sorry I am not a TV repair guy normally, just trying to help out my mom. I will definitely tale a picture of what i am doing tonight when i get back home if that will help. I have downloaded the PS board schematic so that will help. Thanks for all of your help!
                                  • Dani_2024
                                    by Dani_2024
                                    10-28-2024, 05:06 PM
                                  • JDC
                                    (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                    by JDC
                                    ONN 100012588
                                    Issue: No Power, Then Rebooting After Main Board Change
                                    Short answer: replace main board and power board
                                    Technical answer: replace main board and Q306 & Q307 on power board.
                                    Long answer:
                                    TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                    07-15-2022, 07:39 AM
                                  • Asraf Atb
                                    by Asraf Atb
                                    01-27-2025, 05:02 PM
                                  • stylishconsultant
                                    un60j620dafxza - Samsung No Display Problem
                                    by stylishconsultant
                                    Hi All,
                                    Need help.
                                    I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                    So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                    problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                    might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                    09-04-2024, 03:26 AM
