OKITVV37TD stuck in stand by (17PW20 & 17MB22-2) yet another vestel
  • Blanqui
    • Oct 2013
    • 12
    • España
    Hello guys.
    This is my first post asking for help.
    Last week this TV came in. It has the power supply 17PW20 and the mainboard 17MB22-2.
    The set's led was intermitent and would not start.
    Since I know those powerboards are bad, I ordered a new one from my provider. When I got the new board, the set still doesn't work. Now I have a fixed lit led and nothing else works.
    Any ideas?
    Thank you!
    Blanqui.
    Re: OKITVV37TD stuck in stand by (17PW20 & 17MB22-2) yet another vestel
    Try replacing EEPROM, you can use a blank one on this chassis.
    Not continuous blink from LED? Just solid, in standby? What does set do if you press power button?
    • Blanqui
      • Oct 2013
      • 12
      • España
      Yes, the led is just solid and I have all stby voltages ok.
      If I press any button the set does absolutely nothing. I can see the voltage variations on switch board but nothing else happens.
      I don't have a blank eeprom now for this set. Will have to order some.
      Any other things to try in the meantime?
      Thank you!
        17PW20-1 sch
        When you plug in set, stby voltages come up. Then self test begin. ST_BY pin 6 PL803 should change state (cannot remember if high or low), voltages from PSU come up and then after a second or so it turns off and sits there in standby. Then you can turn it on with button or remote. Usually if self test fails you get continuously blinking LED. But maybe older main board will just shut them off.
        I do have a working 17PW20-1 board in a 37" Sanyo I'm working on right now. Can get you a few measurements on that if you need. It works fine, but the inverter has a fault.
        • Blanqui
          • Oct 2013
          • 12
          • España
          Yes, when the power button is pressed, all voltages come on briefly for a second or so, then only remain the stby ones.
          Pin 6 goes from 0.4 (at power on) to 1.8 on stand by.
          Pin 5 stays at 2.7. It should be error_det. But I don't know if high means error or not.
            So, the voltages are all good briefly? Corrupted EEPROM or bad main board then. The main boards in most Vestel sets are fairly reliable, though...
            • Blanqui
              • Oct 2013
              • 12
              • España
              Let's hope it's a bad eeprom, if not, after replacing the power supply, customer won't accept the repair quote.
              So no more for now, time to go to have lunch and enjoy the weekend :p
              Thank you for everything!
              Blanqui.
              • Blanqui
                • Oct 2013
                • 12
                • España
                Hello again.
                I've just replaced the eeprom and the status hasn't changed.
                The set does the same, steady led lit.
                Is there anything else I might try?
                Thank you!
                Blanqui.
                  Check all voltage regulators on the main board and DC-DC if they have any, post a picture if unsure.
                  • Stunt
                    Hp Laptop Stuck on Hp protected by hp sure start screen
                    by Stunt
                    Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                    I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                    I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                    Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                    screen that's it and stuck there. I left it until the following day and i still...
                    09-02-2025, 01:51 PM
                  • alltvrepairs
                    Toshiba / Vestel 42L2863DG stuck with logo on.
                    by alltvrepairs
                    Hi ,
                    have this set with logo stays on and stanby led blining red to green continuos.
                    i have swapped power supply just in case but no difference.
                    Am thinking of needing a firmware update by usb or spi flash?
                    Any one has access to such resource pls?
                    Main 17MB211S
                    Screen :VES430UNDL-2D-N12
                    Label: 10121357 19059 00040
                    -SN: 8238705 900040
                    Thanks,
                    Darren...
                    09-27-2025, 07:38 AM
                  • DXseekerMO
                    Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
                    by DXseekerMO
                    Hello everyone!
                    Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
                    Symptoms:
                    1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
                    2) TV does not appear to turn on
                    3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
                    4) "Power on" terminal on Power Supply has 3.26v
                    5) "A13V" terminals have 12.9v
                    6) Stand-by test jumper on Power Supply has 12.9V
                    7) Optical audio jack on Main Board illuminates
                    8) With stand-by...
                    06-09-2021, 12:19 AM
                  • Biruslapio
                    LG 42PX4RV stuck in Stand-by
                    by Biruslapio
                    I'm now in possession of this very old 2005 plasma TV, the original failure described to me was that it only turned on after hundreds of attempts, eventually it just stopped working.
                    It has stable stand-by 5V and 4.4V AC-ON voltages, the main board red LED lights up, it has all of the secondary voltages generated by standby: 3.3V, 2.5V and 1.8V. Trying to power on via remote or power button does nothing, the signal is received, but it's stuck.
                    The power button was bad, replaced but that did not fix anything, replaced 10V 1000uF, 25V 470uF, 50V 47uF and 50V 10uF capacitors...
                    08-25-2021, 04:28 AM
                  • stormanimal83
                    Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
                    by stormanimal83
                    Hey....
                    Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
                    my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
                    01-18-2024, 02:15 PM
