Panasonic TH-42PZ80B - Completely dead again
    Re: Panasonic TH-42PZ80B - Completely dead again
    Originally posted by tw2005
    is'nt the UT30 series the generation that quite a few are having the SC boards go like the poor chap in the states that had his repaired under wty only to have the same fault 6 months later and be left high and dry out of wty?
    This one powers up but has garbage on the screen. I'm thinking A board fault.
    • tw2005
      • Oct 2011
      • 6458
      Originally posted by Blanqui
      Hello, tw2005.
      I thought tom66 was suffering from the MC201 module but it seems it's not the problem.
      In any case, the problem this module suffers from is the cap between legs 11 and 13 of IC TEA1611T.
      Referring to your request, tom66, there is no mention to what you say. The closest thing is to replace MIP3A and the fuse on the standby power supply. But I guess your fuse is right and don't need to replace MIP3A.
      Thanks, I did get mine going for a while after reflowing that cap, so I'll try what you say as i can should be able to get that cap off with the module in place.
      I've got new TEA1611 ic and caps but I thought the cap ws the culprit just did not expect to learn it's not needed.
        Friend has two lasting 4 and 5 months with just that cap on MC201. They are very nice TVs, the only thing I do not like is the black level is too high. The pro monitor should look nice, if I can get it.
        • tw2005
          • Oct 2011
          • 6458
          Unusual display fault that's for sure with a band either side
            Huh? The pro monitor, yeah, I think that's 4:3 display though, it probably more to do with colour bands along the display when running.
              ...The mystery deepens.
              Here, I was able to get a scope shot of the AC detect signal both during fault and after it (with set operating and producing interference.) Unfortunately, as can be seen, it is not a DC signal, therefore my idea of using a relay will NOT do the trick.
              I think that one of the small ceramic caps on the AC detect board may be bad, one of the ones on the input AC lines, because it is asymmetrical. It appears to be on the negative edge of the AC wave.
              • max-power
                Dell E6540 laptop completely dead after dssasembly
                by max-power
                Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                03-24-2025, 08:49 AM
              • wangbreeze
                T480s random shutoff and then completely dead
                by wangbreeze
                Hello Gurus,
                I got a ThinkPad T480s. It was running fine but suddenly started random shut down. When it turned off, I had to push the reset pin to bring it back to life. But it got aggressively worse and became completely dead. No charging light, no life.
                I did some initial diagnostics with just the board (no battery, nothing attached, and no CMOS battery as well)
                Initial testing of the coil resistance seems to indicate no dead short. The only low resistance I measured was at PL701. It reads 38 ohms.
                charger gave - 20V - ok
                U101B
                02-03-2024, 04:57 PM
              • pavski
                Completely dead MSI z490 tomahawk
                by pavski
                Trying to troubleshoot MSI z490 tomahawk board and would appreciate your help. The board is completely dead and shows no activity when the power button is pressed.
                I have tried to look at the Superio, the PSIN signal seems to be correct (goes from 3.3V to 0 on button press) but the voltage on PSOUT pin is quite low. I
                t is only 0.8V which seems to be incorrect but goes to 0 when the button is pressed.
                Can you please let me know if this is indeed incorrect and what else should I look at next?
                Thanks!
                06-02-2024, 02:42 PM
              • Andreasbest
                Lenovo Thinkpad T14s completely dead.
                by Andreasbest
                Hello.
                I received a T14s Gen1 ( NM-C891 motherboard ) that is completely dead, no indication of life at all.
                I tried hard reset without RTC battery and short both pins of it for 1 minute but no luck.
                Since it's type C connector i have no idea what to measure or where to inject voltage, so any advice are welcomed
                Thank you in advance!
                Schematic & boardview -> https://www.badcaps.net/forum/troubl...cfc-nm-c891-sc...
                03-19-2024, 03:18 AM
                Laptop computer that went completely dead no boot no power light no hard drive light
                by sam_sam_sam
                See pictures for type of laptop computer
                I checked switching power supply brick 19.2 volts multi meter only
                No booting without switching power supply connected
                Checked switching power supply with an (28 volt ) incandescent light bulb it lights then hooked up the switching power supply again now the laptop and boots like normal
                What the heck is going on here...
                04-04-2025, 04:58 AM
