Sylvania LC427SSX FIRMWARE - Anyone Have it?
  • Neonpeon
    • May 2012
    • 41
    After a call to Sylvania today, it is apparent that I am not going to be able to get any firmware from them. According to 2 customer support people, and a manager, they no longer have access to firmware for their tvs.
    I am having a problem with the Audio not coming back up after restarting the tv on the HDMI ports. Seems there is an update 1.6 that is supposed to fix this.
    This is same chassis as the Magnavox 42MF438B/F7, I am wondering if I can flash it with this firmware.
  • Neonpeon
    • May 2012
    • 41
    Re: Sylvania LC427SSX FIRMWARE - Anyone Have it?
    I seem to keep answering my own questions here lately
    Anyway. The Magnavox firmware DOES work. It only needs to be renamed.
    Magnavox file: M42OS_107_AB.ecc
    Sylvania file: L42OS_107_AB.ecc
    Software History
    Version 1.4 Audio missing on some analog cable channels.
    Version 1.5 No picture when some DVD players are connected using HDMI.
    Version 1.6 Missing audio or video when switching from one HDMI input to
    another.
    I have included the firmware file here.
    Maybe this will help someone.
    • notallbad
      • Oct 2012
      • 1190
      Hi
      Great work!
      How did you do the update? USB, Programmer
      • Neonpeon
        • May 2012
        • 41
        USB. Copy the firmware file to a FAT32 formatted Flash Drive. Turn off the tv before inserting the flash drive. Turn on the TV and it should pop up with a message to update the firmware on the screen.
        One note: Although this worked great for my Sylvania TV, when I go into the menus, it shows Maganvox. Not a biggie for me, but it may not be great for a customers TV.
        This DID fix my audio problem.
        • zr2steve
          • Nov 2013
          Beware! Causes Sylvania remote to be non functional.
          • HoF_Wain
            • May 2014
            • Murica
            I know I'm a bit late to this forum, but can anyone else like Neonpeon confirm that the remote stops working after the update of the firmware?
            • bigsplit
              • Jul 2016
              I know it's long since past this being posted. But just for anyone who comes across this as I did. I can confirm that this does in fact causes the oem remote to no longer work. I would also like to add though, if you attempt to use a universal remote you must connect to it as a Magnavox. But it works great.
              • zklgfs
                Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                by zklgfs
                I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                08-11-2025, 02:14 PM
              • TheUser
                Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                by TheUser
                Hello to everyone ,
                This is my first post here, and i would like to share with you a small story in case you can help me.
                Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                02-10-2024, 02:07 PM
              • gurj1979
                Ubiquiti firmware help. US-8-150W POE
                by gurj1979
                Hi guys.
                I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                Got New chip and writes good.
                THE PROBLEM...
                It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                Does anyone have a Good Firmware I can have?...
                07-22-2024, 05:13 PM
              • Slapito
                Request for EC firmware for MSI Vector GP66 12UHSO (MS-15441 ver 1.0)
                by Slapito
                I'm currently repairing an MSI Vector GP66 12UHSO laptop with a motherboard reference MS-15441 ver 1.0. The EC chip (ENE KB9548QF2) on the board appears to be damaged and needs to be reprogrammed.
                Can someone please send me the firmware (EC/Embedded Controller) or indicate where I can download the correct EC firmware version corresponding to this motherboard model?
                I already have access to the BIOS downloads on the MSI support page, but need specifically the EC binary or its equivalent firmware image.
                I already downloaded the BIOS update file from msi official...
                10-09-2025, 02:00 AM
              • wattage
                by wattage
                Hello Badcaps Community,
                07-13-2025, 04:41 PM
