Samsung Plasma PN50B450B1D Dim picture, black pixels
    Re: Samsung Plasma PN50B450B1D Dim picture, black pixels
    The meter might be being fooled by some of the low pulses.
    • Glitcher
      • Mar 2013
      • 673
      • USa
      So the x-main is bad? Would it also explain the low Yscan voltage?
        If you unplug X-main is Y-scan better?
        • Glitcher
          • Mar 2013
          • 673
          • USa
          I unplugged the x-main from the psu and then from the ctrl board but Yscan would still is stay lower than the spec. Only time I can get Yscan to the specs is if I unplugged it from the ctrl board.
          Also theres a green LED that's been blinking as the tv is on fromt he control board, not sure if it means anything.
            Lower than spec, by how much? Few volts OK. More than 20% lower bad.
            • Glitcher
              • Mar 2013
              • 673
              • USa
              #26
              around -176-179v fluctuating
              sticker says -193v
                Yeah that could be caused by a shorted Ve what happens with control+Y-main hooked up but X-main disconnected on both cables (white and grey power)? If Vscan is OK then it's probably a shorted intermittent Ve causing the fault on the X-main.
                Just realised I remember doing the 42" B450 with bad X-main and same poor picture.
                • Glitcher
                  • Mar 2013
                  • 673
                  • USa
                  #28
                  I see, guess the only thing left would be a bad driver IC on the Xmain? I checked every through-hole FET and diode out of circuit and they were all good. I hate checking SMD parts =( not very much successful with those.
                    If I see a driver IC I would always replace it at the same time as a FET, just because they are difficult to test.
                    • Glitcher
                      • Mar 2013
                      • 673
                      • USa
                      #30
                      But then none of the FETs were bad, so not sure which I should replace or what I should be looking for
                        I have to admit I just found a cheap X-main and swapped it, guess they're a lot harder to get hold of now as that was about 2 years ago...
                        • Glitcher
                          • Mar 2013
                          • 673
                          • USa
                          #32
                          Ive been checking everything on this X-main and I can't seem to find one thing bad on it... there isn't as much components on the back of the board as I thought.
                          So far I just replaced the chip in the 2nd picture that leads to the ribbon to the control board but no luck.
                          Been checking especially around where the Ve test point is but no luck either...
                            Vcc fuse is good?
                            • Glitcher
                              • Mar 2013
                              • 673
                              • USa
                              #34
                              I assume you mean this one? And yes both fuses are good.
                                Yes, that one. And do you get a good 15V or so going into that board?
                                • Glitcher
                                  • Mar 2013
                                  • 673
                                  • USa
                                  #36
                                  Yes, getting 15.48V on both ends of that fuse.
                                  • Glitcher
                                    • Mar 2013
                                    • 673
                                    • USa
                                    #37
                                    Also a note, I'm measuring voltages on random parts on the X-main and (ie, the FEts, diodes, etc.) And they all are fluctuating and unsteady. Is this normal in an x-main
                                      I just checked the SS board of a Panasonic plasma and the output to the panel, despite being a square wave, measures 120V DC on a true RMS meter.
                                      • Glitcher
                                        • Mar 2013
                                        • 673
                                        • USa
                                        #39
                                        I just realized that I never answered this question. With the y-main board connected to psu and to the ctrl board. And the X-main disconnected (both connections) from the crtl board and the psu, the Vscan voltage is still low. It seems like it is independent from the x-main?
                                          Depending on the design it could be that the -Vsc only rises when the Ve has sufficient load i.e. X-main working and panel lit fully. To test you could try hanging a 10W light bulb or xmas light off the Ve.
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                            09-07-2024, 05:50 AM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • kerberos137
                                            Sony xbr-65x930e faded to black; now has backlight but no picture
                                            by kerberos137
                                            Hopefully someone can help me out. This tv was working perfectly until a few weeks ago. At some point, the TV just faded to black, but sound continued playing. It almost looked like smoke on the screen as it faded from the bottom left corner toward the top right. Took only a second or less, but wasn't instant. After restarting, it turned back on and worked fine for another day or two. Then it happened again more or less the same way, but in a slightly different direction, again with sound continuing. I thought it was working fine after another restart, but looked a bit dimmer than before. Then...
                                            11-29-2022, 05:40 AM
                                          • Dodgethis
                                            Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                            by Dodgethis
                                            Hello all,
                                            This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                            09-11-2024, 07:39 AM
