Panasonic Viera TC-P50GT25 SC Board Replacement
  • Liberty Caps
    • Oct 2013
    I have the 6 blinks failure on this TV so I followed the Panasonic tech guide's troubleshooting flow chart and disconnected the SC20 connector and the C10 connector and got 8 blinks which tells me that I need to replace the SC board.
    The board on my tv is a TNPA-5081 and the sticker on it says 5081ap-u025001170. Can I use the SC board from a TC-P50G25 TV? I think the only difference is that mine (TC-P50GT25) is 3D capable and the TC-P50G25 is 2D only.
    I found this following list in another thread on here and my understanding is that AP and AF boards are the same and therefore should be interchangeable. Is this correct?
    Revisions
    none
    TC-P54G20
    TC-P54G25
    TC-P54S2
    AF
    TC-P5032C
    TC-P50G20
    TC-P50G25
    TX-P50G20B
    TH-P50V20A
    AG
    TC=P46G25
    AH
    TC-P42C2
    TC-P42G25
    TX-P42G20B
    AK
    TC-P50VT20
    TC-P50VT25
    AL
    TC-P54VT25
    TC-P55ST30
    AM
    TC-46PGT24
    AP
    TC-P50GT25
    AY
    TX-P50VT20B
    AW
    TH-50PF20U
    TX-P50G20B
    Re: Panasonic Viera TC-P50GT25 SC Board Replacement
    Probably not, unfortunately. The 3D panel is capable of being brighter on 3D mode, and can be driven at a higher frequency. The 2D sustain may struggle with the required output power. It might work, but no guarantees.
    • Jacksoft
      Panasonic Viera TX-P46G10E 11 blink even after fan replacement
      by Jacksoft
      I have here a Plasma TV TX-P46G10E that before had a problem where it had issues with 11 blinks (FAN SOS) BEFORE starting normally. After that it works for all day long.
      It had some bad cold solder and I remade them all. After I replaced a fan that was half-dead (no RMP signal from the respective pin, but ok with 9V).
      Now the TV power up instantly and works perfect... only without the backplate!
      If the backplate is placed on the TV shutsdown after about 10min and start blinking with the 11 blinks. If I shutdown and re-powerup it starts blinking after a bunch of...
      11-26-2023, 07:22 AM
    • Jagster
      Panasonic SA-XR25,Looking for a good replacement cap
      by Jagster
      I have a Panasonic SA-XR25 surround receiver that is not working and I believe it may have a faulty capacitor. This large capacitor near the mains power input has a plastic top that is bulged out. Anyhow, I'm trying to find a like replacement but Panasonic doesn't seem to make this capacitor any longer and I want to find a suitable replacement. It has an "AUDIO" designation written which I presume means something important in relation to the capacitors design characteristics. Can someone advise on what would be a good replacement? Image attached.
      The sleeve info:
      10-27-2022, 09:34 PM
    • Ama Chur
      Panasonic Viera LC470EUN (SE)(M2) T-Con issue?
      by Ama Chur
      After watching some youtube videos and checking some forums, I'm at a loss. With both ribbon cables connected, we have no image. With the left one pulled out, the screen is black and white, split down the middle. With the right cable removed, it is all black. Backlight is working fine and we have sound and can open applications. We are strapped for money right now and are hoping to repair whatever the issue may be. I think the TV was manufactured in 2012, so I'm aware that may not be possible. Edit: Found a single vertical line of blue pixels on the left side of the screen with one of the ribbon...
      02-21-2025, 08:12 PM
    • BigPete
      Panasonic Heatpump Dryer Repair
      by BigPete
      I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
      The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
      In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
      Unfortunately the whole machine has to come apart to fix it.
      I have...
      11-01-2025, 06:40 PM
    • badcappo
      Dead Panasonic Viera TX-P65STW50 Plasma TV
      by badcappo
      Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
      Diode type G972s6 - D101 with a short
      Mosfet 06N90E - Q301 shorted
      Fuse T5AH 250V - F103 blown
      Diode D301 shorted
      Relay DG1U-17VDC II - RL001 blown
      I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀...
      11-24-2024, 11:27 AM
