lcd problem whats your verdict impact damage or not
  • wreksta
    • Aug 2013
    • 508
    • england
    I think this is caused by impact damage this is only problem with whole set
    whats your opinions techies
  • freakaftr8
    • Oct 2012
    • 3743
    Re: lcd problem whats your verdict impact damage or not
    Certainly looks like impact trauma. Have a 46 inch sony that has similar issue. That one fell on its face.
    • freakaftr8
      • Oct 2012
      • 3743
      With the set off look with a flashlight on an angle. Can you still see it?
        If it's an older 32" or 37" Samsung panel, it's due to some internal failure of the LCD panel... not impact damage but all the same as it's unrepairable.
        • theone111
          by theone111
          3. Problem: TV shuts down
          07-22-2024, 10:36 AM
        • Zeonalbasta
          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
          by Zeonalbasta
          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
          09-13-2024, 01:17 PM
        • Gibon378
          Problem with stopping audio and video for no reason
          by Gibon378
          PC Specs:
          • CPU: Ryzen 5 1600
          • GPU: GTX 1080 Palit JetStream
          • MOBO: ASRock ab350 PRO4
          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
          • PSU: XFX 650W (don't remember what model)
          • OS SSD: ADATA SP920
          • OS: Windows 10 21H2
          Problem description:
          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
          11-19-2022, 09:41 AM
        • grimacelord
          iPhone XR - Liquid Damage - No Power - Possible BB/BB_PMU Problem?
          by grimacelord
          Hey guys. I have an iPhone XR that I am working on that suffers from liquid damage and currently does not power on or charge properly. I have ruled out a parts problem by swapping out the lightning dock charging flex cable and a new battery to no effect. The logic board has been ultrasonic cleaned, as there was visible corrosion on the board.
          I've taken some measurements and I am leaning on something wrong with BB_PMU or BB itself, but wanted some other opinions. I'll outline everything I've done thus far:
          Problem:
          Liquid Damage. Visible corrosion in...
          10-03-2020, 08:22 AM
        • perzyk23
          Lenovo T580 - LCD Panel problem - error 0288
          by perzyk23
          Good morning,
          I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
          10-25-2024, 12:42 AM
