iPhone XR - Liquid Damage - No Power - Possible BB/BB_PMU Problem?
  • grimacelord
    • Jan 2017
    • 380
    Hey guys. I have an iPhone XR that I am working on that suffers from liquid damage and currently does not power on or charge properly. I have ruled out a parts problem by swapping out the lightning dock charging flex cable and a new battery to no effect. The logic board has been ultrasonic cleaned, as there was visible corrosion on the board.
    I've taken some measurements and I am leaning on something wrong with BB_PMU or BB itself, but wanted some other opinions. I'll outline everything I've done thus far:
    Problem:
    Liquid Damage. Visible corrosion in the area around C4191 (PP_VDD_MAIN).
    Phone does not power on.
    Phone attempts to charge at varying ~0.10A
    Diagnosis & Repair Attempts So Far:
    Ultrasonic cleaned the board due to the corrosion.
    Tried new lightning dock flex cable - No effect
    Tried new battery - No effect
    Found short on PP_VDD_MAIN. Replaced C4191 and short cleared - Still no power or proper charging.
    TRISTAR/HYDRA Tester says Hydra is OK.
    I have checked a whole bunch of power rails both for voltage and for shorts. I don't THINK I found any shorts, but I did find some rails missing that are tied to BB and BB_PMU. I will post my measurements below. The first measurement reading on each line is diode mode measurement to ground (red probe on ground, black on rail) and the second measurement is the voltage.
    Testing was done with the board connected to a DCPS set to 3.8V no screen, battery, or lightning dock connected.
    A few of them at the end I just got their diode reading and not voltage, but will gladly get those if someone needs to see it
    Various Power Rails:
    pp3v0_nand - 0.449 | 2.61V
    pp1v8_s2 - 03.15 | 1.8v
    pp1v8_always - 0.632 | 1.79V
    pp3v3_usb - 0.324 | 3.3
    pp_vdd_main - 0.325 | 3.82v
    pp_gpu_sram - 0.481 | 0v no screen connected
    pp_vdd_boost - 0.393 | 3.76
    pp1v1_s2- (short?) 0.095 | 1.069
    pp1v2_SOC - 0.538 | 0v
    pp_cpu_sram - 0.335 | 0v
    pmu_vbatt_vsense- 0.786 | no batt connected
    pp1v26_s2- 0.446 | 1.27v
    pp0v9_nand - 0.474 | 0v (normal?)
    pp_batt_vcc - 0.442 | 3.82v no batt connected
    pp_cpu_ecore - 0.443v
    pp_cpu_pcore - 0.259
    PP_SOC_S1 - 0.267
    pp3v0_s2 - 0.417
    pp_gpu - 0.018
    And then here are the measurements strictly involving BB/BB_PMU. These are all voltage measurements. The ones that are zero volts, I also took diode measurements and none of the zero volt rails are short:
    pp_0v9_SMPS1_BB_SRAM - 0.9V
    PP_0V8_SMPS2_BB_DIG - 0V
    PP_1V3_SMPS3_XCVR_ANA - 1.24v
    PP_0V77_SMPS4_BB_CORE - 0.87v
    PP_1V0_SMPS5_XCVR_CORE - 1V
    PP_1V85_SMPS6_IO - 1.846v
    PP_3V15_LDO1_VFE_AUX - 0V
    PP_1V8_LDO2_VFE_LNA - 0V
    PP_3V3_LDO3_USB_HS - 3.3
    PP_1V8_LDO4_BB_MEM - 0v
    PP_1V24_LDO5_USB_SS - 1.25V
    PP_1V1_LDO6_BB_IO 1.1
    PP_1V2_LDO8_HBPAD 0V
    PP_1V8_LDO9_GNSS 0v
    PP_1V8_LDO10_XCVR_HI 1.74
    So it seems to me that my main problem is likely the BB_PMU IC itself which is U_PMIC_K in ZXWTools or the BB itself which is labeled U_BB_K, but that is just somewhat of an educated guess.
    I was hoping someone could take a look at what I've measured and help me in the right direction. I don't have either ICs in stock for the iPhone XR so before I ordered some chips needlessly, I wanted some help in making sure I'm on the right track in my thinking.
    Thanks guys!
  • mon2
    A1466 Macbook Air (Liquid damage repair)
    by mon2
    Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
    Macbook AIR Model A1466 Diagnostic 09-01-2021
    Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
    Problems & Resolutions
    1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
    09-01-2021, 09:31 AM
  • rilley
    MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
    by rilley
    I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
    I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
    My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
    And the resistor L4004 is literally burned.
    From what I see from the schematics, it does not affect any other rails, only the connection to the display...
    07-10-2024, 01:57 AM
  • Jenzo
    MacBook A1989 overheating after liquid damage
    by Jenzo
    Hey everyone,
    Had a MacBook pro 13" 2018 (A1989) come in for liquid damage. The only liquid damage was all around UB400. It was most likely soda, so there wasn't that much corrosion. I reflowed the UB400 and the QB chips with some flux, and replaced the caps/resistors that were in bad shape. Seemed to be working fine at first, but the next day when testing it again, the laptop charges and boots fine, the CPU would overheat, and U7210 would get to 70 degrees Celsius as well. I'm testing with only screen and battery connected at this point.
    I can't figure out how...
    05-13-2023, 07:58 AM
  • mitchw
    MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
    by mitchw
    Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
    It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
    I quickly took it apart and washed the liquid residue off the mainboard.
    The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
    The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
    Now the laptop...
    07-16-2025, 07:55 AM
  • larrysito111
    dell alienware m17 r5 LA-L761P liquid damage no image on lcd 2red 7blue runs on external
    by larrysito111
    got here a liquid damaged alienware
    the laptop had damage in the area of the kb9542qf2 all sorted and now laptop working and turns on but i have no display
    so if i start and connect usb-c display it works otherwise it is giving me the 2red and 7blue
    so with the usb-c external monitor is getting to bios and OS
    otherwise not
    so if it is in the os and i connect another lcd via onboard hdmi it is working no problem 2 lcds (1 usb-c + 1 hdmi)
    but still not the internal monitor
    (tested 3V and 5V going to the...
    06-12-2025, 04:16 PM
