Panasonic TH 50PZ80U Transparent Vertical Bar
  • jmp906
    • Oct 2013
    • 10
    I have a 2008 Panasonic Viera TH-50PZ80U. When the TV warms up, a 3 inch transparent yellowish vertical bar appears in a fixed position from top to bottom on the right side of the screen. The bar overlays any video input including the TV's menus. It first appeared with images that have white backgrounds. It now appears with any background. It may disappear for a while if I tap on the chassis. I have re-seated some of the ribbon cables with no effect on the bar. Has anyone else experienced this? Any suggestions on how to diagnose and solve this problem? Thanks much.
    Re: Panasonic TH 50PZ80U Transparent Vertical Bar
    This will be a loose ribbon but it will be on the bottom of the plasma panel not the side. Have you reseated those ones? Very common issue on these panels.
    • jmp906
      • Oct 2013
      • 10
      Thank you, Tom. I did reseat the ribbons that lined up with the bar without success. I will have to try to reseat all of them.
      • jmp906
        • Oct 2013
        • 10
        I reseated the ribbon cable but the transparent vertical bar still appears. Removing the ribbon cable replaces video with static in the bar. Is the next step to replace the C1 buffer board? Is there any way to determine if the problem is with the board or the components in the ribbon cable?
          Which board does the bar cover, C1, C2, ...?
          Also, can you provide a picture of the fault?
          • wreksta
            • Aug 2013
            • 508
            • england
            His buffers are clip type forget what i mentioned lol
            • jmp906
              • Oct 2013
              • 10
              Thank you. I posted a picture of the fault. Had to start a new thread "Panasonic TH 50PZ80U Transparent Vertical Bar-image"
              • jmp906
                • Oct 2013
                • 10
                Image of transparent vertical yellow line. This line appears after the TV is on for 45 minutes.
                • freakaftr8
                  • Oct 2012
                  • 3743
                  Had same tv with same issue in the left side if the screen. Turned out to be a bad chip on the ribbon of the panel. Eventually it got to the point where it caused a sos shutdown. Had to eventually remove the sos on the ss board with owners blessing. It kept going.
                  • BigPete
                    Panasonic Heatpump Dryer Repair
                    by BigPete
                    I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                    The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                    In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                    Unfortunately the whole machine has to come apart to fix it.
                    I have...
                    11-01-2025, 06:40 PM
                  • JDC
                    (SOLVED) - Panasonic TH-50PZ80U - No HDMI
                    by JDC
                    Issue: Panasonic TH-50PZ80U works fine but has no HDMI output.
                    Easy solution: replace main board.
                    Advanced solution: replace HDMI chip on main board.
                    Unless you've got the time, tools and the hands of a surgeon, skip the advanced solution. For you beginners out there reading this, you would need to use a combination of a heat gun, flux, solder, and probably a microscope to succeed. If there is someplace you can send the board in for repair, you can go for that. From what I've read elsewhere, I don't think this TV will even do 720p.
                    If none...
                    08-10-2022, 06:10 AM
                  • Andre Gilbert
                    by Andre Gilbert
                    Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                    Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                    11-20-2024, 08:52 PM
                  • mopenstein
                    Looking for Vertical IC for RCA Chassis CTC159L CRT
                    by mopenstein
                    I'm working on my 27" RCA console TV built in 1990. It had some vertical rollover for a few months that went away after being powered on for a few minutes. I had been meaning to open it up and check it out but it had total vertical collapse before I could get to it.
                    Now that I have the time I opened it up and found a couple leaky capacitors around the vertical ic. So I figured the caps went bad and cooked the vertical IC.
                    I got the caps out and replacements on order. But when I took out the Vertical IC I saw that the chip numbers have been almost completely wiped...
                    09-24-2023, 10:41 AM
                  • pni
                    LG 49uf695v vertical coloured lines
                    by pni
                    Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                    11-14-2025, 03:15 AM
