Hitachi P50S602 Plasma Power Supply Testing?
  • Robb
    • Sep 2013
    • 159
    Does anyone know how to test a power supply? My TV turns on then back off again within a few seconds. I don't think it's the Y-SUS as it produces a picture before it shuts down and disconnecting the Y-SUS and X-SUS doesn't allow TV to stay on. Any suggestions will be greatly appreciated, there seems to an internet blackout on this issue.
    Re: Hitachi P50S602 Plasma Power Supply Testing?
    Do you see a PS-ON, RL-ON and/or VS-ON labelled pin on connectors on power supply board?
    • Robb
      • Sep 2013
      • 159
      No, other than the power in, the connectors are CN23, CNPPS & CN06, as follows:
      (from top to bottom)
      CN23 - Va, Va, NC, Vcc5.1V, GND, GND, GND, NC, Vs, Vs
      CNPPS - AUDIO 17V, AUDIO GND, +17V, GND, +5.6V, +5.6V, GND, GND, STBY5V, GND, AC CLOCK, POWER1, POWER2, AC OFF, NC
      CN06 - Vcc1.5C, GND, Vra, Vrs, Vcego, Vsago, AC OFF
        OK, I think the signals are POWER1, POWER2, Vsago, Vcego.
        You want to have the power supply connected and power the set up, check the various voltages on these pins, and see how they change when the power button is pressed. If they drop out, then the power board is probably OK and the main board is shutting down.
        • Robb
          • Sep 2013
          • 159
          When I press the power button, the connections go from 0V to as follows:
          POWER1 - 4.3V even after fans stop (shuts itself off) MAIN
          POWER2 - 3.2V even after fans stop (shuts itself off) MAIN
          Vcego - 3.0V until fans stop then 0V LOGIC
          Vsago - 3.0V until fans start then 0V LOGIC
          I could not read the connections from the PSU Board so I read them from the MAIN & LOGIC Boards.
            OK, this indicates the logic is shutting off the power, which is likely because it detects a fault on either YSUS or XSUS board.
            • Robb
              • Sep 2013
              • 159
              So, if the YSUS or XSUS is faulty, the display can still work briefly (black background with multicolored pixel static/snow).
              I have disconnected the cables between PSU & XSUS and then XSUS & YSUS, but it still won't stay powered on. I also disconnected the Y-Buffers and same thing. Not sure how to locate the source of the problem.
                I have no experience with Hitachi plasmas, but pink snow makes me thing more of a YSUS than XSUS, if that helps...
                • Robb
                  • Sep 2013
                  • 159
                  Thanks for helping me rule out the PSU! You are the best!
                  • alltvrepairs
                    Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                    by alltvrepairs
                    I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                    I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                    Any one met this problem in the past?...
                    10-08-2025, 07:34 AM
                  • lp20th
                    Samsung Plasma TV Power Supply Issue
                    by lp20th
                    I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                    11-28-2023, 10:28 AM
                  • navagator
                    Hitachi Power Supply Unit Interchangeability
                    by navagator
                    I have a Hitachi 57F710E rear projection set with a bad power supply board. I've tried to fix it with help from this forum as well as another one, but without success. Today I found a Hitachi rear projection set for sale on Facebook that looked just like mine. After contacting the seller I found out it was a 51F510. According to the service manuals my set uses a HA01312, POWER UNIT DP4X-DM_24W and the 51F510 uses a HA01313, U901, POWER UNIT DP4X_24W.
                    Does anyone know if these 2 power supply boards are interchangeable?
                    Thanks.
                    01-08-2024, 07:53 PM
                    by sam_sam_sam
                    07-01-2024, 06:34 AM
