Tecknika LCD32-M3
  • flocko
    • Nov 2012
    • 1121
    Tecknika LCD32-M3
    What am i missing?i pick this set up dead no standby,when i opened the back you could see the problem a batch of bad caps on the power board, so with all the bad caps replaced and a few more for good luck the power board is now working at full steam on all outputs,i must point out at this stage i have no remote for the set, so i try tuning by the side buttons select DVT with source and then menu, menu comes up but will not select tuning, so i try TV as source this time it lets me go to auto tune but will only tune analogue.i then try with Av as source but menu again will not go to tuning,all the other inputs work when selected with no problems.The main and the DVB board are made by Haier and i know the factory reset but as i say have no remote, so please any suggestions as to what to try next Thanks Flocko
  • finntricky
    • Jan 2014
    • 449
    Re: Tecknika LCD32-M3
    i have the same problem, with the same model, did you ever sort it.?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Look up the mother board model and try to purchase a remote, being a low end set the remote should just work if not you may have to enter a code.
      • finntricky
        • Jan 2014
        • 449
        see other post, Tecknika LCD32-M3
        • flocko
          • Nov 2012
          • 1121
          Hi finntricky yes I am bad I should have came back to finish the post,but seeing as no one got back to me I must have thought Fxxx them. the problem was solved with the correct remote, I tried all the codes on the pound shop remotes they only work some things on the set but not all hope this is of help to you Flocko
          • finntricky
            • Jan 2014
            • 449
            chears m8
              LCD LED TV Service Menu Codes
              ALL LCD LED TV SERVICE MENU CODES
              Service Menu Code with Board Name
              China Universal Board / Jumper Board Service Menu Code
              Changhong Ruba Service Menu Code
              Ecostar LED TV Service Menu Code
              Orient LED TV Service Menu Code
              Haier LED TV Service Menu Code
              TCL LED TV Service Menu Code
              Samsung LED TV Service Menu Code
              LG LED TV Service Menu Code
              Videocon LED TV Service Menu Code
              Supra LED TV Service Menu Code
              Toshiba LED TV Service Menu Code
              Symphony LED TV Service Menu Code
              Veste/ LED TV Service Menu Code...
              10-31-2024, 03:58 AM
            • cstout
              DeLonghi AC Remote only accepts 3V
              by cstout
              Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
              The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
              I can't find any schematics...
              06-03-2024, 03:53 PM
            • Mc_Millian
              Toshiba 50lf711u20 fire tv remote not pairing
              by Mc_Millian
              I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
              The Tv model number is: 50lf711u20 Rev B.
              I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
              I've tried 3 different remotes which should be fully compatible with this TV.
              Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
              The power button, along with the volume,back,select, and directional...
              04-07-2022, 12:15 PM
            • edugimeno
              HiSense 55A7500F won't obbey to remote after power on
              by edugimeno
              Hi! I have this TV set that does the following:
              1) I press the red power button on the remote
              2) The TV turns on normally
              3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
              4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
              Then after it's off, it would again accept the TURN ON from the remote and same again
              BUT:
              -The remote does show the correct IR beam while observed thru a phone camera
              -The TV works fine while using the MiRemote...
              03-14-2023, 11:22 AM
            • wattage
              AOC AG493UCX 49-inch monitor - Firmware request
              by wattage
              Hello Badcaps Community,
              The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
              07-13-2025, 04:41 PM
