My Philips 42MF231D/37 has a bad Y-Sustain and Lower Y-Buffer. The Y-Buffer has only one IC chip that is blown (I think I can handle fixing that). The Y-Sustain, however, appears to have about 15 blown resistors (see photo). Does anyone know how to tell what resistors I need to replace the blown ones and also what other components commonly fail on the LJ92-01200A Y-Sustain? Thank you in advance.
Philips 42MF231D/37 Y-Sustain w/Blown Resistors
Re: Philips 42MF231D/37 Y-Sustain w/Blown Resistors
How do you know they are failed? Do they test bad?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
No, that's not how the continuity range works.
Resistors have varying value, the value on them is coded in ohms. Read the value off (look up resistor colour code) and compare to readings on the appropriate ohm range. However, it's rare for resistors to fail without visible marks such burning, discolouration or cracking.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
You have the dreaded LJ92-01200A Y-Sus and Y-buffer combo problem. I've dealt with this on a few occasions. I believe the usual failure suspect is one of the TA36N30P mosfets under the long, narrow heat sink, but you could have other issues, also. You'll have to at least lift a leg of each mosfet under that heat sink to test them, since they're in parallel.
Do a search for "LJ92-01200A" on the forum, and you should find plenty to read
I had Coppell repair one of my boards, because I didn't have time to deal with it: http://www.ebay.com/itm/Y-sustain-LJ...item255ea6337e
http://blog.coppelltvrepair.com/2010...according.htmlLast edited by capkid; 09-27-2013, 11:34 PM.Comment
Yep blown buffers wreak havoc on thise y boards. Like capkid said remove the heat sync pull ine leg on each mosfet. One or more shorted. Replace the shorted one. Look for diodes shorted and open resistors. There will be some.Did I leave the soldering iron on?Comment
Thanks for the replies. I put the Y-Sustain back in along with the good upper Y-Buffer and the TV displayed the top half of the picture. Does that mean that the Y-Sustain could be good or that just the components going to the good Y-Buffer (upper) are good?
I looked at the long narrow heat sink, but I'm not sure how to remove it properly. I'm going to try to desolder the legs connected to the board on the heat sink and get at it that way, if I don't hear/read any warnings about it.Comment
If you get any part of an image the Y-sustain is good, you have a bad lower Y-buffer.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
It may not be long before your upper goes, which could take out your Y-Sus. With a TV this old, I'd replace the lower Y-buffer and call it done.Comment
Thanks, Tom, that's exactly what I wanted to hear. I'm just going to replace the lower Y-buffer IC when it comes in the mail and hope for the best. I also ordered a flux pen to facilitate the soldering of the IC. I'll post back next week with a follow up. Thank you all!Comment
Re: Magnavox 42MF231D/37 Y-Sustain w/Blown Resistors
WIN!!!!!!! My first TV repair!!! You nailed it, tom66! After ripping some pads off the Y-buffer trying to replace the IC that had failed, I bought a used y-buffer and I'm very happily playing Black Ops 2 right now and the picture quality is better (colors brighter) than my Hitachi 42EDT41 - which isn't really saying that much though I was quite impressed at first due to it being my first plasma.
I was a little concerned that there was going to be some other issues as I think CoppelTVRepair said the Y-SUS and other Y-buffer usually go when one buffer goes but everything is looking good for now...it's been on a few hours.
by aidanmoHello,
I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
I thought maybe the speakers got damaged, so I replaced them - no dice.- Using the internal speakers, it always happens.
- Using the headphone jack, it never happens.
- Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
by reessiHello,
My friend asked me to replace the wire going from this SMPS 20v adapter to the charger for a 18v Lithium Battery for a drill.
The cable had frayed and been touching, as a result the 5 Paralleled R200 (0.2 ohm) resistors had blown O/C, they are connecting the main -ve rail to the output wire.
The output was jumping around 13v and dis-appeared when a load like the charger was connected, they measured 900ohms.
I experimented by replacing at first a single 0 ohm and then a 2.2ohm in and the output was restored at 21.62v and 21.65v respectively... -
by WidgetHello,
We have one of those heated throw blankets you plug into AC power. The other day it went *bzzzbzzzbbzz... pop*, so I opened it up to find what appears to be two resistors gone *poof*. (R7 & R14 in picture)
luckily, we have a second blanker with what appears to be identical controller, so I opened it up to take a picture
According to the good controller PCB, R7 = 9531, & R14 = 103
Online SMD resistor calculator says
R7 - 9531 = 95.3kohm
R14 - 103 = 10kohm
Is this correct? Would all I need is a 10k... -
by TinkerTronHey everyone,
I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
Instead, here's what's been bugging me so far:
The schematic...3 Photos-
by gurj1979Hi folks.
I have a Medion Erazer X15803 with board number MBPGK7CP7C-SN12 (no schematics on the internet) which uses Monolith Buck Converter MP2949A for CPU power. It has 2 burnt out resistors.
R332 is missing the solder tabs so I cant even get any reading from it.
R330 shows 5ohm.1
What are the values of these 2 resistors ?
Image attached.
Thanks.... - Loading...
