Sony LED TV KDL-46EX520 No Video, but the Sound is OK.
  • Caleb
    Smokin IC's
    • Feb 2013
    • 645
    Re: Sony LED TV KDL-46EX520 No Video, but the Sound is OK.
    Power supply voltages look ok to me, I think the consensus is that the tcon needs to be replaced. Shopjimmy shows they used 3 different tcons on this model make sure you get the right one for your tv
    Liberating magic smoke one part at a time
    • soeren
      A2442 - No sound over internal speakers and no video playback
      by soeren
      I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
      All happened after the battery ran out of power overall several days when I was on vacation.
      I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
      07-26-2024, 01:24 AM
    • JRade
      Audio video receiver KENWood KR-V990D,no sound
      by JRade
      When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
      The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
      I replaced the capacitor C303/0.047F, nothing changes.
      I'm asking for help, what should I do next?
      Thanks in advance!...
      08-05-2025, 10:23 PM
    • FrancescoV
      Onkyo HT-R390 no sound output, video output ok
      by FrancescoV
      Good morning everyone,
      I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
      The firmware reported is the following:
      M:1.00/11107BLP
      D:?.??/????????
      O:1.00/11107AL
      The DSP firmware given the question marks seems corrupt.
      On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
      05-11-2025, 02:59 AM
    • iglitare
      Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
      by iglitare
      i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
      Backlight seems to work, Sound (Setup menu after reset) works.
      If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
      Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
      With my small knowledge i would think at least the cables are good.
      Can this happen because of a bad tcon board?
      Or is it always a bad/shorted...
      09-04-2025, 07:13 AM
    • bbenalmadena
      Old Sony VAIO da0hk5mb SVE1512E1E disable Radeon video card
      by bbenalmadena
      I have a Sony VAIO SVE1512E1E (motherboard da0hk5mb) video card is broken, has artifacts, I want to disable it, the processor is an I3-3110M that supposedly has an integrated Intel GPU and I want to disable the onboard Radeon so that can be used.
      I download some schematics, and tried to remove VPL1, but then the laptop starts some leds, and shut off. Should I try to lift VPL1 and VPR47 and pass a cable to one tip of VPR47 and the other back to VPU1 to see if that works or it is pointless?
      That seems to be some feedback to VPU1 and I guess if it does not detect voltage, laptop...
      08-30-2025, 10:40 AM
