lg 50pg4000 loses sound remote stops working and switches off
  • wreksta
    • Aug 2013
    • 508
    • england
    Re: lg 50pg4000 loses sound remote stops working and switches off
    it does mate ill try that
    • wreksta
      • Aug 2013
      • 508
      • england
      cant get remote working now at all meaning none respondant
      • Ltank
        • Jun 2013
        • 776
        The remote board wires go to a different section of the main board that the audio. If it goes out after warmed up, I would try freeze spray on the voltage regulators and audio chip. When the audio drops out what is the voltage to the chip? The preamp IC has a lower voltage than the audio amp. Check both while your there. Do you loose the power to the IR remote rcvr facing the front of the set? I am responding from my phone so I am unable to look at a schematic.
        • Ltank
          • Jun 2013
          • 776
          A fast and easy test is to unplug the IR from the main board and use the buttons on the set for on/off and volume up/down. If the board is bad it can cause these problems
          • wreksta
            • Aug 2013
            • 508
            • england
            once I lose sound the remote works tv led flashes to show this but will not do the functions pressed
              Which indicates it's receiving the instructions but discarding or ignoring them - the main board is at fault. On some of these main boards, there's a SUB MICOM for processing IR, standby and LED functions. The SUB MICOM connects to the main processor by I2C interface, typically. If there's a problem with the main processor or the interface, this effect might be observed.
              As for repair? Main board swap is probably the only thing that can be done.
              • wreksta
                • Aug 2013
                • 508
                • england
                #27
                tom got a hairdryer is it worth trying it
                • wreksta
                  • Aug 2013
                  • 508
                  • england
                  #28
                  cant even try factory reset from service menu as cant get in just yet takes ages to get the remote working
                    Well as the fault is caused by it running for a long time, and hence heat likely, then a hairdryer will probably make the problem worse. If you can't do a factory reset then there is no option but a board swap.
                    • LEECH666
                      Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                      by LEECH666
                      Good day ladies and gentleman!
                      I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                      This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                      I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                      01-19-2024, 05:46 PM
                    • laidman
                      Yamaha psr ew400 piano loses sound
                      by laidman
                      Yamaha PSR EW400 piano intermittently loses sound and shuts down.
                      Youtube people recommend verifying that the DC jack's solder connections aren't broken, and the replacement of a couple of capacitors in the vicinity of the DC jack. While these solutions might work, I'd feel a lot more secure if I had a schematic to help me check the status of the myriad components.
                      Schematic and suggestions are welcome.
                      11-18-2023, 05:13 PM
                    • Christos Tsiligiannis
                      Marian Trace Alpha sound card repair help
                      by Christos Tsiligiannis
                      Hello to the forum.
                      My name is Christos, I am new to the forum here and i am posting from Greece.
                      So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                      To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                      So i tried asking for a schematic from the company and they would not give me one. Instead they...
                      11-18-2024, 05:26 AM
                    • ChaosLegionnaire
                      by ChaosLegionnaire
                      09-13-2022, 09:02 AM
                      HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
                      This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                      09-12-2024, 02:30 PM
