Insignia NS-32LCD - Framerate issues.
  • bigclown187
    • Sep 2013
    • 6
    My Insignia has been having framerate issues as of lately. It has been working great for 4-5 years and now it is randomly dropping frames or something (maybe like going from 23.976 FPS to 15 or so...not sure). Not really sure how to explain it. Any help on diagnosing the problem would be greatly appreciated, thanks.
    I have the TV already open and looked over the power supply and other 3 boards and do not see any visible issues like bad caps. The power seems to be fine which leads me to believe it is not the power board causing the problem.
  • Toasty
    • Jul 2007
    • 4171
    Re: Insignia NS-32LCD - Framerate issues.
    The NS-27 I worked on didn't appear to have bad caps that were in fact bad. Yes, the obvious "domed" tops were there on all the boards, but many were not. The Blue ESR meter weeded them out. Total of about 25 across all 3 boards.
    T
    veritas odium parit
    • bigclown187
      • Sep 2013
      • 6
      Thanks. I'll try to weed out the bad caps.
      • gretti
        MSI Z370-A Pro, works but does not power off or reboot and USB issues
        by gretti
        I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
        The MSI BIOS included the ME firmware for the board. The size...
        10-16-2025, 02:14 AM
      • SoulFreeze
        Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
        by SoulFreeze
        Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
        After repairing the above issue, I realized the following remaining problem,
        Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
        The computer recognizes headphones are connected and displays a popup in windows
        Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
        06-21-2025, 09:53 AM
      • Nagyesz
        Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
        by Nagyesz
        I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
        All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
        How can I extend its lifespan? Could reflow help?
        It has ryzen 5 5500h, rtx 2050, no soldered ram.
        Example of the artifacts:
        03-01-2025, 11:11 AM
      • cajoeg
        Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
        by cajoeg
        Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
        The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
        02-10-2025, 04:01 PM
      • pwnjuice
        Bitlocker issues
        by pwnjuice
        Customers laptop had a Motherboard go bad and replaced it. they want to try to get data but. I am having bitlocker issues. I will list below
        Issue 1: When connect the drive to my computer to decrypt it I get this message. "there are no supported protectors on this drive the drive cannot be unlocked"
        Issue 2: When I run powershell as admin and try manage-bde -protectors -get e: I get this message. " ERROR: An attempt to access a required resource was denied. I also get the same error when I try manage-bde -status e: When I try the same with terminal with
        01-06-2025, 05:33 PM
