22me402v led tv strobe light effect
Re: 22me402v led tv strobe light effect
Well new power supply is in. Still doing the same thing. So power supply is ruled out. Ehat else.should I look for that will cause the strobing on the led backlight?Did I leave the soldering iron on?Comment
I have seen this syptom before on a Vizio TV. Check your large electrolytic caps on the iverter board They will have a high ESR. May not even be bulged. usually as ESR changes so does the value of capacitance that affects the timing of the oscillator circuit.Comment
Thanks for the reply. Its an led tv thou. All the voltage conversion is done on the power supply. It only needs 40v to power the led stripDid I leave the soldering iron on?Comment
I forgot to mention that when the backlight adjustment is all the way up the voltage coming out of the BL_adj is 3.3v. On the mainboard out to the ps. when the backlight adjust is all the way down in the menu the voltage is .6v. so it appears the main board is doing its job. Which only leaves me to believe that there's something wrong in the LED strip somehow. Is there a way to verify this?I tried unplugging the mainboard and of course there's no backlight at all or no picture so it's really hard for me to tell what could possibly be going on here but it's definitely not the power supplyDid I leave the soldering iron on?Comment
Has anyone ever has a problem with the led backlight? What normally are the symptoms of a defective led backlight?Did I leave the soldering iron on?Comment
This tv is buggin me. All voltages test within spec. 2 different power supplies and same fault. BL_adj goes from 3.3 to .5v with backlight level in menu so the power supply is getting its full 3.3 volts but for some reason the lights are dim and flickering. I texted each led with my meter and they all home within spec and all lit up bright in diode check mode. but yet when all connected the lights are flickering dimly. the power supply has BL_sw and bl_adj both getting full 3.3 volts. All the other pins seem like they're doing what they're supposed to do according to the label on the power supply.Did I leave the soldering iron on?Comment
I got bold and pulled the backlight cable while on. Rocking it back and forth shows that 1led 1 2 3 and 4 act lije a ground and center pin is the 44vdc. As I rock it the outer pins make the screen dimmer and brighter. Its turning on and off the four banks in the stripDid I leave the soldering iron on?Comment
Well tv now has a new mainboard and power supply. Still flickering.like a mad strobe light. Its definitely in the led strip but im not seeing how its possible. Diode tested every led and came up the same on my fluke. And all light up in the tv and diode test. What gives?Did I leave the soldering iron on?Comment
Hey there
I am working on the same power supply as yours. My symptoms are loud squealing and ticking sound. May I ask what did you repair in your original PSU to get it to work?
- All caps in spec
- All diodes ok
- All through hole resistors okay
- All SM fuses okay
- All transistors measure okay (i think)
- Transformer T601 has continuity
- Suspecting IC001 "HAI 7209PC" to be the cause...Comment
Well the parts for my supply were more than the supply was worth so I purchased a replacement. But if yours is squealing disconnect ribbon to mainboard. Does squealing stop? I had another one of these that caused the power supply to do that and it was actually a mainboard issue. But my original issue was main mosfet blown in hot section of power supply and 2 zener diodes.Did I leave the soldering iron on?Comment
Do you have a standby light when this happens? Unplug mainboard and check pins for 5v on power supply. If you have 5vdc suspect mainboard to be at fault. . I have a mainboard here at home that causes the ps to squeal and it does not provide a standby light.
also try with mainboard connected and led strip disconnected.Last edited by freakaftr8; 10-25-2013, 04:54 PM.Did I leave the soldering iron on?Comment
Ok got in tbe new led strip and guess what... Still doing the stribe light!!!! Thats all boards replaced now. Im really srumped. I swapped ps twice too. One I thought was rhe prob. Next.one still did it. bew mainboard and led strip that I personally saw work perfect in another panel.Did I leave the soldering iron on?Comment
What's it like at max brightness? Could it be that the LED brightness is controllled by pulsing the LEDs and maybe it's just a poor design?
has anyone else viewed the TV and also sees the same strobing effect?
Just throwing some thoughts out there?Comment
No actually at max backlight the pulses seem to get worse actually. This is odd. it's also something that I can't pick up on a camera for video and actually show because the pulsing in the flickering itself at the camera can't pick it upDid I leave the soldering iron on?Comment
Yes had 2 friends look at it. They both say its messed up. The strobing is not steady. Somerimes tgr backlight briefly cuts out and I can hear this in tandem with the power supply ticking.
its not bright by any means.
The picture is quite dimly lit.Last edited by freakaftr8; 10-27-2013, 02:25 AM.Did I leave the soldering iron on?Comment
Have you jumpered the BL ON and DIM signals to rule out the main board?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
Have had two Acer K272HUL monitors die with the same symptoms:
- Blue power light is illuminated while the monitor is plugged in
- Black screen (no splash screen, etc.)
- Power button doesn't do anything
Opened it up and checked for bad caps and components, evidence of burns, etc. - everything looks fine.
Power supply voltages are fine.
There are some signal lines on the power supply harness that goes from the power supply to the logic board, not sure what these should be at.
Anyone have any ideas?...-
12-09-2023, 10:22 PM -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
Assuming...7 Photos -
by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
i know that in linear power supply the noise will be very low comparing to SMPS supply.... - Loading...
