Coby TFTV3227 Takes Time to "Warm Up"?
  • Maxstang
    • 61
    Hey Guys.
    I have a Coby LCD TV that starts fine, but has no picture (backlight) for the first 10 minutes or so. Eventually it "warms up" and displays beautifully. I figured it must be dying caps (although the TV is only a year old) but looking at the power supply, they all look good. I don't see any cold solder etc. Anybody have any ideas where to check first? Here's the power board.
    Re: Coby TFTV3227 Takes Time to "Warm Up"?
    Do you have a digital multimeter available?
    • Maxstang
      • 61
      Yep got a multi. Thanks Tom. I'll rig it back together so I can test some voltages. Dang Coby TV is REALLY hard to work on as everything is mounted to the plastic back of the case component side DOWN.
      What should I be looking for?
        Just check the outputs from the power board. If they're out of whack (usually labelled, but common voltages are 5V and 12V) then it is probably a power board issue.
          Check the DC voltage right at the two legs of that large 450vdc cap laying side way, it should have 370~390VDC when you activate the power switch. Be careful not to touch anything with your hands.
          • Maxstang
            • 61
            Sorry for the wait. Too many soccer games...
            Well this is interesting. I got it all back together, and it started right up...repeatedly. I can't get it to display the "warm up" behavior again. I'm thinking cold solder joints now. I must have moved something when I disassembled it. I'll go over the board and see if I see any cracks etc.
            I did test the voltages for future reference:
            Large cap reads 169V at standby, 392 when TV is on. Voltage is steady.
            This board has five main lines:
            The 12V lines both read 12.2-12.28V. The readings wandered constantly. I guess it's unregulated?
            The two 5V lines were 5.06V, very steady.
            The standby voltage was 5V.
            Interestingly, with this board, only the standby voltage is on when the TV is on standby. The 12V and 5V lines are at 0V.
              That is correct, when TV is off, the 12v/24v are turn off to save power, only the standby power is on to run the main board. You can read basic guide under my signature.
              • Maxstang
                • 61
                Thanks Bud. I have a samsung where some of other lines are still active at idle (13V). Perhaps that's what wrong with it!!!
                Here are some photos of solder joints on the power board. I'm surprised how many look like cold joints. I sucked and resoldered basically all the major components on the board. The worst looking ones were in the backlight headers and transformer. I've circled a few.
                CFL Headers
                One of the Mosfets
                I'm watching it right now. Seems to be working. I'm gonna let it sit on standby and occasionally turn it on in the next 24 hours as a burn in.
                • Maxstang
                  • 61
                  Well it appears I spoke too soon. I'm getting video artifact and loss of signal now. I'll post a short video when I get time later today.
                  • Maxstang
                    • 61
                    Hmm.. I'm trying to get a video of the problem, but it's very intermittent. I get colored lines across the video, both vertical and horizontal in many different widths and colors as well as video stutter and complete loss of video, but not the backlight. Looks to me like I have a problem with one of my 5V lines... I need to get it to do it consistently and measure the voltage outputs when it's happening. Right now it looks great...
                    • Maxstang
                      • 61
                      Here it is. I can get it to behave this way by leaving it off but on standby for a while. When I turn in back on, it displays this behavior for a few minutes and then the picture stabilizes and its fine after that. I'll take it back apart and test the voltages on start up and post them.
                      http://s122.photobucket.com/user/max...61520.mp4.html
                      • Maxstang
                        • 61
                        I should have mentioned that the backlight doesn't flicker. Just the video.
                        • Maxstang
                          • 61
                          OK. Pulled it apart and tested the power supply during the flicker. As I noticed earlier the 12V lines both wander from 12.24V to 12.29 and when they do, I get flicker and artifacts on the screen. The voltage swings settle down after a few minutes and this corresponds to when the picture clears up. The 5V lines are rock solid. I also checked the voltage on the big cap for fluctuations, but didn't see any.
                          SO....are the 12V lines fluttering because the regulations sucks, or because the main board is drawing power erratically? Anyone?
                          • truep
                            • Aug 2010
                            • 373
                            Where are you located? I sold a Sanyo to a guy a couple of years ago that displayed similar symptoms. I tested it at my house, and it worked fine, even after being outside on a 100 degree day or inside at 75.
                            I took it back to him and it started flickering. It turned out his ac power would drop to 94V whenever his AC kicked in!!
                              "12.24V to 12.29" that is nothing to be concern, you may have to look at it with the scope to really see what the variation is on the waveform. That 12V may be used on the T-CON board. 12V is usually for the Audio circuit, the 12V may be fed to the T-CON regulated power supplies on the T-CON. I would try cooling and use the hair dryer for heating the T-CON board to see what happen.
                              • Maxstang
                                • 61
                                Good suggestions!
                                Thanks Bud. I'll give that a try. This TV has the worlds smallest TCON board. It's only 2x2. I'm wondering if it actually uses the 12V at all. Here's a pic.
                                  Holy Cow!
                                    I've seen similar boards. One was marked "AU OPTRONICS TEST BD"; I'm guessing it wasn't intended for production, but it worked, so it ended up in the final product.
                                    It's just translating some of the LVDS signals. The tab drivers do most of the work.
                                      There may be another long board on the LCD panel assembly for the Gamma voltage ref generator and buffer and some switching PS. 32" TV with one Inverter transformer!
                                      • Maxstang
                                        • 61
                                        There's another small board visible inside the LCD display, but I don't think it's accessible. The LCD is in a plastic case! There doesn't seem to be a 12V path to it anyway as the ribbon cable from the T-CON is the only thing that connects to it. I'll try the freeze spray on the T-CON and on the main board and see if I can make it do its thing...
                                        • jagg
                                          Laptop MSI-16k5 Board model MS-16k51 V1.1 takes a long time to send video
                                          by jagg
                                          Hello, the laptop It turns on and off several times, it takes a long time to send video, possibly it is bios?
                                          Here are the bios and the schematics.
                                          Could someone help me verify that the bios is correct? thank you so much !!...
                                          11-22-2023, 03:36 PM
                                        • novak2
                                          Panasonic th-42px60en plasma TV takes time to turn on and make clicking noises
                                          by novak2
                                          Hello there,
                                          I recently bought a Panasonic th-42px60en plasma TV second hand. The problem is :
                                          The TV takes time to turn on from cold (being unplugged from the night for example), it tries to turn on with the clicking sound, then shuts off, then retries and so on. The TV is still working, just it takes time to boot.
                                          From what I've read it seems to be bad capacitors on the power board, but I just want to see if anyone had the same problem with this TV.
                                          Thanks in advance.
                                          09-25-2020, 02:34 PM
                                        • titomno2
                                          Gaming Laptop Zephyrus S17 TFT not detected every time !
                                          by titomno2
                                          Hi guys,
                                          I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
                                          So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
                                          On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
                                          Then the screen won't work for a long period of time.
                                          If I wait 1 or 2 hours it work again most of the time.
                                          When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
                                          01-19-2025, 08:27 AM
                                        • itzusman
                                          1708 EMC3164 macbook have power issues
                                          by itzusman
                                          Hi Masters.
                                          My 1708 EMC3164 macbook have power issues. First it was working fine but a bit slow in booting. Net day i turned it on and it didn't powered on. And i tested with usb meter it suddenly @ 20v it takes 2.6 ampares and cpu gets hot. Then i checked the baord and PPBUS_G3H was short to ground. I injected 1v to it it takes 350ma and cpu gets warm. After opening L7410/20/30 there was inly L7420 line was short then i injected 3v to PPBUS_G3H and it takes 2.5 amps and U7420 got hot and i desolder it. Now after that in the start it takes 0.580 amps and goes to 620-30 mili amps....
                                          07-13-2024, 06:19 AM
                                        • F R 2568
                                          Dell Latitude 5420 does not start (no post) need help to find the reason why
                                          by F R 2568
                                          Hello all,
                                          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                          If the laptop is only connected to the AC adapter (battery removed):
                                          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                          The power/battery...
                                          01-08-2025, 05:45 AM
