panasonic viera red half screen
  • wreksta
    • Aug 2013
    • 508
    • england
    Re: panasonic viera red half screen
    Originally posted by tom66
    If you got those lines with the D board tests, the D board is bad.
    The Vs and Vda(=Va) would not cause this. Whatever you do, do NOT touch Vda or you can kill the panel! The -Vad, Vscn and Ve cannot cause this either. Neither can buffer boards SU/SD or sustain/scan board SC or sustain SS. It's between A & D and given you isolated A, by doing testpatterns (and all showed noise right?) the D is bad.
    and I wont touch them just with that electrical surge lazer noise from ymain
    though maybe vs va to high
    I seen that behaviour before on old goodmans gtv when you messed with vs the panel would flick and click then switch off
      Check them by all means, but don't adjust them unless you have to.
      High Vsus typically causes overblown image (too white) or blue sparkles. Low Vsus causes pink discolouring. On these panels at least.
      • wreksta
        • Aug 2013
        • 508
        • england
        any info on the d board checks etc tests could the ldvs stil cause this or defo bad d board
          The D board generates most of the patterns internally, so if the noise affected ALL the patterns, then the D board is definitely faulty.
          • wreksta
            • Aug 2013
            • 508
            • england
            nothing to fix then no reflow of solder points diode checks mosfets etc
            • wreksta
              • Aug 2013
              • 508
              • england
              #26
              will this one work its for the 80 not the 85 but cant seem to find a 85 anywhere in uk
                85 is different panel, better black level and motion performance. Maybe will work but cannot be certain. Seem to remember there being a surplus of '80 boards as they rarely fail. Generally quite reliable sets too.
                • wreksta
                  • Aug 2013
                  • 508
                  • england
                  #28
                  think im going to examine d board before buying one nothing to look for or heat up to isolate the affected part
                  • wreksta
                    • Aug 2013
                    • 508
                    • england
                    #29
                    tom service manual referring to d board as ldvs
                      Panasonic have always referred to the D board as the D board, as far as I'm aware.
                      • wreksta
                        • Aug 2013
                        • 508
                        • england
                        #31
                        which one of mine is faulty ldvs under main av or the av board
                          The D board. I think that's what you mean by LVDS. It's marked "D". Refer to service manual for diagram of boards.
                          • wreksta
                            • Aug 2013
                            • 508
                            • england
                            #33
                            im confused tom so its not my main hdmi scart etc input board just the ldvs /tcon board underneath
                            • wreksta
                              • Aug 2013
                              • 508
                              • england
                              #34
                              im lost now so with test patterns on I thought this was generated from main av board im wrong arnt I
                              so a 22 quid board in there and she will live you rekon this is the board your referring to isn't it
                              http://www.ebay.co.uk/itm/1811548629...84.m1423.l2649
                                Test patterns are generated on these sets by BOTH the A and D board. Each has different test patterns. The white AGING test, which is slightly tinted, is generated by the A board, as are a few others. The gradient, colour bar, solid colour, 10% fill/50% fill patterns and the scrolling bar are generated by the D board.
                                This is different to most TVs. I'm glad Panasonic did it this way as it makes diagnosing the board easy.
                                Refer to this document for more information.
                                If that board is from the PZ85, it should fix it. If it's a PZ80, no guarantees. Remember to match the part suffix to your current D board as well. Part suffix printed near part number e.g. TNPA9999 AW. You must match both TNPA9999 and AW.
                                • wreksta
                                  • Aug 2013
                                  • 508
                                  • england
                                  #36
                                  thank you tom so defo no way could be ldvs cable then
                                    Well I think the original fault was LVDS if that's any consolation but a D board fault has now appeared. Perhaps both were present and first was hard to see.
                                    • wreksta
                                      • Aug 2013
                                      • 508
                                      • england
                                      #38
                                      now last clarification since looking at the set today I cant guarantee it has ever stayed on mate so have a fiddle with the ldvs then if no go order a replacement d board/tcon/ldvs board
                                      • wreksta
                                        • Aug 2013
                                        • 508
                                        • england
                                        #39
                                        tom will you take a look at these they all say that they are same model number is this right
                                        http://www.ebay.co.uk/sch/i.html?_od...A4439&_sacat=0
                                          You've gotta match the suffix stamped in the yellow box after TNPA.....
                                          I do not know about the powering off. Check all power connectors seated, power must be off while doing so.
                                          • Zelek11
                                            Panasonic Plasma screen interference on left half of screen
                                            by Zelek11
                                            My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
                                            This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...
                                            10-14-2022, 04:54 PM
                                          • armoured_smiler
                                            Panasonic Tx-40cx400b top left half screen not displaying correct
                                            by armoured_smiler
                                            Trying to work out if this is TFT problem or TCon issue.
                                            The TV powers up but the top half of the screen, from the right it is OK, but as you look across to the left halfway across it starts get duller and duller until it is very dark on the lefthand side, currently I trying to clean the remote as it seems to have something film wise on the pads stopping it from registering buttons pressed.
                                            Also when changing the screen size of Windows PC display to say to a smaller pixel sizewindow, the original window displayin the top left stays/takes a few seconds to disappear?...
                                            04-08-2024, 03:40 PM
                                          • Chrissygizmo
                                            by Chrissygizmo
                                            02-10-2025, 12:33 AM
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • renech
                                            panasonic TH-42PC77U plasma television half screen problem
                                            by renech
                                            hello,
                                            I hope someone on this forum can assist me.
                                            I have a panasonic TH-42PC77U plasma television.
                                            the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
                                            i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
                                            I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
                                            I have read some posts that suggest the problem is related to the boards on the left...
                                            12-12-2022, 06:53 PM
