panasonic viera red half screen
Re: panasonic viera red half screen
Check them by all means, but don't adjust them unless you have to.
High Vsus typically causes overblown image (too white) or blue sparkles. Low Vsus causes pink discolouring. On these panels at least.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
The D board generates most of the patterns internally, so if the noise affected ALL the patterns, then the D board is definitely faulty.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
85 is different panel, better black level and motion performance. Maybe will work but cannot be certain. Seem to remember there being a surplus of '80 boards as they rarely fail. Generally quite reliable sets too.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Panasonic have always referred to the D board as the D board, as far as I'm aware.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
The D board. I think that's what you mean by LVDS. It's marked "D". Refer to service manual for diagram of boards.
im lost now so with test patterns on I thought this was generated from main av board im wrong arnt I
so a 22 quid board in there and she will live you rekon this is the board your referring to isn't it
http://www.ebay.co.uk/itm/1811548629...84.m1423.l2649Comment
Test patterns are generated on these sets by BOTH the A and D board. Each has different test patterns. The white AGING test, which is slightly tinted, is generated by the A board, as are a few others. The gradient, colour bar, solid colour, 10% fill/50% fill patterns and the scrolling bar are generated by the D board.
This is different to most TVs. I'm glad Panasonic did it this way as it makes diagnosing the board easy.
Refer to this document for more information.
If that board is from the PZ85, it should fix it. If it's a PZ80, no guarantees. Remember to match the part suffix to your current D board as well. Part suffix printed near part number e.g. TNPA9999 AW. You must match both TNPA9999 and AW.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Well I think the original fault was LVDS if that's any consolation but a D board fault has now appeared. Perhaps both were present and first was hard to see.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
tom will you take a look at these they all say that they are same model number is this right
http://www.ebay.co.uk/sch/i.html?_od...A4439&_sacat=0Comment
You've gotta match the suffix stamped in the yellow box after TNPA.....
I do not know about the powering off. Check all power connectors seated, power must be off while doing so.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by Zelek11My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...10-14-2022, 04:54 PM -
Trying to work out if this is TFT problem or TCon issue.
The TV powers up but the top half of the screen, from the right it is OK, but as you look across to the left halfway across it starts get duller and duller until it is very dark on the lefthand side, currently I trying to clean the remote as it seems to have something film wise on the pads stopping it from registering buttons pressed.
Also when changing the screen size of Windows PC display to say to a smaller pixel sizewindow, the original window displayin the top left stays/takes a few seconds to disappear?...2 Photos -
by ChrissygizmoHello everyone, I’ve just been given a Samsung UE55JU6800K smart tv as it had white spots on the screen due to the led lenses falling off. After refitting them & putting the tv back together I thought it was a nice easy fix for a free bedroom tv , then I tried it before screwing the back into place. I realised that the right side of the screen was darker than the other side, I removed the screen again as I thought the backlights had failed but they are fine.
I put the screen back in place & turned it back on . The screen seemed to be ok again but different screens on the same... -
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by renechhello,
I hope someone on this forum can assist me.
I have a panasonic TH-42PC77U plasma television.
the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
I have read some posts that suggest the problem is related to the boards on the left... - Loading...
