panasonic viera red half screen
    hi im doingf this for a friend just trying to find out what causes the red screen
    ive enclosed a picture
    Re: panasonic viera red half screen
    Model number would be helpful. If Z80/Z70/X80/X70 series Viera loose LVDS can cause this...
      th-42pz85b cheers tom
        check cable between A & D fixes this 99% of time.
          Been to ladies house today and had a look jesus those wires n clips are a pain
          anyways couldnt get screen to sort it self out did notice if i messed with ldvs cable the screen on the left the one that was reddish would go green white etc so suspect ldvs board and cable
          any thoughts
            Usually on the bottom end. Cable is fine, in most cases, but the connection comes loose. I am watching a 46" Viera that I fixed with same issue. Once you get connection right it stays, suggest unclipping and reclipping connector.
              tried and tried ldvs makes cicking or screen does certain ways of cable is it worth getting another ldvs board ? can no test be done to rule that out
              is there other things to try thing is I just got giving it and its a nice set
              also the ymain when powered down sound like its having a hissy fit sort of like an amp noise funny to say more like a laser gun noise lol
                It is probably not LVDS board. Maybe you need a new LVDS cable.
                The SC (similar to Y-main) board can sometimes make noise when powered off, this is normal.
                  tel you what ill test the ldvs cable both sides I think
                    How?
                      I messed around got a screen almost perfect tom had few coloured lines on the left part of screen then started making a clicking noise whist screen flashed then went off is this normal
                        How?
                        dunno checked cable seems impossible
                          tom whats causing this clicking want me to up a vid of it starts off not to bad then gets a red boarder starts flashing and clicking then turns off
                            Uhh. I have no idea. I'd be careful if you have pixel vertical lines. Can be sign panel is bad. I didn't reseat cable with unit running due to risk of panel damage. It's a bad idea to reseat cables with anything running can cause lots of problems.
                              I didn't mate I turned it off first heres a video
                              http://s2.photobucket.com/user/wreks...021-1.mp4.html
                              don't think there pixel vertical lines mate cant I do screen patterns in service to tell me if panel good whats the procedure
                                You can:
                                Hold VOL- on set and press 0 three times on remote. Release VOL-.
                                Wait some seconds... screen should flicker and service menu should pop up.
                                Press RED twice to get initial pattern then RED for each subsequent pattern. Note some patterns are generated by A board, but most by D board.
                                  hi tom just did above test problem is still there
                                  these are not lines like pixel lines they are flashes of different colours etc
                                  do you think vid board is naffed can you test this at all
                                    I got a sneaky feeling the vs va and other voltages are not correct haven't tested these yet that ymain noise is quite alrarming but ill bite the bullet if you say I should
                                      If you got those lines with the D board tests, the D board is bad.
                                      The Vs and Vda(=Va) would not cause this. Whatever you do, do NOT touch Vda or you can kill the panel! The -Vad, Vscn and Ve cannot cause this either. Neither can buffer boards SU/SD or sustain/scan board SC or sustain SS. It's between A & D and given you isolated A, by doing testpatterns (and all showed noise right?) the D is bad.
                                        so replace dboard or fix is there anything obvious to test mate is the d board the main av
                                        cant I heat parts up to see if affected area can be mended
