42px5d-eb no picture
  • wreksta
    • Aug 2013
    • 508
    • england
    Re: 42px5d-eb no picture
    is this with tv powered tom I don't fully understand mate as theres pins are under the board please explain mate
    if need be I can solder a 2 wires to the underneaths pins and test that way
      TV powered on. You can usually access the leads topside, but if you have to solder wires then you can do it that way too, just make sure to use good insulated wires because of the high voltage.
      • wreksta
        • Aug 2013
        • 508
        • england
        and I just connect either probe to them when on
        just for clarification theres no risk of shock is there bit scared on that one lol
          You are dealing with potentially 150V DC, so yes, there is a shock hazard. All LCD and plasma televisions present a shock hazard when live testing, if you are not confident please DO NOT continue it is not worth losing your life over.
          • wreksta
            • Aug 2013
            • 508
            • england
            im confident enough just checking mate
            • wreksta
              • Aug 2013
              • 508
              • england
              #26
              im gng to solder 2 wires to those red caps tnight mate and test but thng is the z board nor the y's heatsinks get hot this is with tv constantly on
              • wreksta
                • Aug 2013
                • 508
                • england
                #27
                Any ideas why the y and z would remain cold on the heatsinks i left it powered up for up to 1hr
                  If the panel ain't lit, it ain't consuming power, so the sustains won't heat up.
                  • Gadjet
                    Looking for a Fuse T4AL/250V
                    by Gadjet
                    I've got a Monitor that's not showing any video, and I found this blown Fuse. As you can see from the photos, the board location has T4AL / 250V. Any assistance is greatly appreciated. Thanks!...
                    06-15-2025, 09:16 AM
                  • corrize
                    A funny fuse story – Lumix LX100 II
                    by corrize
                    Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                    I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                    The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                    There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                    And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                    10-19-2023, 09:58 AM
                  • Tr0ll
                    by Tr0ll
                    Original T-con:
                    First replacement T-con:
                    10-07-2023, 07:48 PM
                  • JJAAMM
                    by JJAAMM
                    Problem
                    07-06-2023, 06:01 AM
                  • TR103
                    by TR103
                    - it keeps rebooting
                    01-22-2025, 04:12 PM
