Hitachi 32LD6600B strange picture
  • ceo81
    • Oct 2013
    • 5
    • Turkey
    Re: Hitachi 32LD6600B strange picture
    i also have a vestel 32" lcd tv. i saw that this hitachi tv has the same parts with my tv so, i have a problem like that. my tv is working sound is coming but no screen mean there are only some vertical and colored lines on black screen. so what can i do for it ?
    • bflare
      • Sep 2013
      • 16
      • england
      Hello, I changed the cap which appeared to be bad but no difference. I am not sure what to change, the main board or T-con. Any suggestions?? Just to add that the fault with the picture is all to the right hand side which isn't apparent in the pic I posted.
        Check the voltage regulator on the t-con board. I would swap the t-con board.
        • bflare
          • Sep 2013
          • 16
          • england
          Thanks for your help. How to I check the voltage regulator??
          • killian6pk
            • Apr 2010
            • 502
            With the switch on your meter to DCvolts put black probe on ground (metal on back of tv) and red on each of the 3 leads of the voltage regulator and report the readings back here. There appear to be 3 regulators all on the lower left side of your TCon board. They have 3 legs and a flat metal tab at the top. The tab and the middle leg are connected together. The body is black plastic. Also did you change the caps circled in blue or just the green cap? You should have changed all of them that you circled. Also did you use good brand (panasonic etc.) and low esr caps?
            Have you ever stopped to think and then forget to start thinking again?
            As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
            • ceo81
              • Oct 2013
              • 5
              • Turkey
              #26
              Which one is the voltage regulator on my t-con board. can you show me on the picture.
              • bflare
                • Sep 2013
                • 16
                • england
                #27
                I will check the regulators. Also i will admit i only changed the 1 off green cap. I got the cap from Maplin electronics not sure who the manufacturer is. I guess i should change the other caps before trying anything else???
                • mecha1166
                  Un70nu6900 taped lvds, how to fix washed out 1/2 picture?
                  by mecha1166
                  I am getting these 70 inch Samsungs daily. Dead set light comes on goes off, dark screen. Tried taping the problem lvds cable pins 13 to ? pin, used about 9 mm scotch tape. Picture comes on, no distortion lines, looks good, but 1/2 of screen is washed out. Problem seems to always be the last little strip on the bottom. Has anyone found what is actually the problem? Possibly one of three diodes there? I have a pic but it is washed out on 1/2. Anyony had success in fully restoring the picture? Thanks.
                  07-03-2024, 05:03 PM
                • KYBOSH
                  Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                  by KYBOSH
                  Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                  No picture but you hear the TV static (white noise) playing loud and clear.
                  The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                  But it seems they didn't get too far and just left it.
                  When I first took a look I was amazed at how pristine the inside looked.
                  Its as if the TV had been in a time capsule.
                  Caps looked like they were just pulled off the self.
                  Copper coils had no sign of corrosion on...
                  02-01-2023, 11:10 PM
                • Tr0ll
                  by Tr0ll
                  Original T-con:
                  First replacement T-con:
                  10-07-2023, 07:48 PM
                • JJAAMM
                  by JJAAMM
                  Problem
                  07-06-2023, 06:01 AM
                • TR103
                  by TR103
                  - it keeps rebooting
                  01-22-2025, 04:12 PM
