Panasonic TC-P50G10 7 blinks, now 6 - Need help
  • Jcarro
    • Sep 2013
    • 8
    I have looked through several of the threads on this site and have not found the exact answers to my questions so I created a new thread. Here is the background info.
    Yesterday, while watching my P50G10, there was a loud pop and the screen went out. At first I shut it off to prevent any possible problems but turned it back on once I read online about the error codes being displayed by the LED. The LED showed 7 blinks. I pulled the power cord and tried to find more info. When I checked the LED again it now displayed only 6 blinks. It is now consistently displaying 6 blinks only. I found the manual for this model but no troubleshooting guide to help with narrowing down the faulty component.
    I did find a troubleshooting guide for a TC-P50ST50. This guide had a flow chart that showed how to confirm the component for a 6 blink fault. It stated that I should pull the SC20 connector and see if the blinks changed to 8. The blinks stayed at 6 so this guide states that the A board is bad.
    My concern is that this guide may not be applicable for my model of TV. Is this the correct way to narrow down the issue on this set? I would like to get this set fixed correctly.
    Jason
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P50G10 7 blinks, now 6 - Need help
    6 blinks is generally Sc board, SC boards are a common failure but buffers should also be resistance checked in case they have shorted as well.
    Does also mention SS, SD,SU as possibles but the SC would be key suspect.
    This is probably what you want.
    • Jcarro
      • Sep 2013
      • 8
      Where would I find a reliable replacement board?
      • Jcarro
        • Sep 2013
        • 8
        thanks for the guide. Looks like I need to do more work now.
        • Jcarro
          • Sep 2013
          • 8
          went through the procedure and it looks like the SC board is the problem. I will try to find one and report back with results.
          • johnboy1313
            • Nov 2012
            • 1959
            There is a kit on eBay for the SC board (assuming it's the TNPA4782 that I'm dealing with) for $62. It includes 2 diodes and 5 MOSFETs. From the description, if there is a short at connector SC2, it is the correct kit for this board. I am not the seller, nor can I confirm that this kit will do the trick. Just a heads up.
            • Jcarro
              • Sep 2013
              • 8
              Thanks, I saw that too. Just not sure if these parts will fix my issue. I have 6 blinks now. I do see one of the surface mounted components that appears to be blown, it has the part # "HB1707FP" (or MB1707FP or N1707FP) on it, I think. There is a hole in the top of this component and it is hard to read.
              • Jcarro
                • Sep 2013
                • 8
                • Jcarro
                  • Sep 2013
                  • 8
                  It is actually "M81707FP" it is a Mosfet per the webpage that I found. It states, "M81707FP is high voltage Power MOSFET and IGBT mod-ule driver". No place around me has a board, just a few repair places on Ebay that I have found so far. I will keep looking.
                  • Biruslapio
                    Panasonic P58V11B 8 and 12 blinks error "fix"
                    by Biruslapio
                    Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                    Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                    04-13-2021, 07:13 AM
                  • Andre Gilbert
                    by Andre Gilbert
                    11-20-2024, 08:52 PM
                  • Alicat
                    Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                    by Alicat
                    Stopped by this site trying to fix my parents Panasonic Plasma TV.
                    Model number is TH-50PZ85U
                    Power comes on and the red power light stays on solid.
                    Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                    I also hear a few clicks.
                    I also think my parents said there was a thunderstorm and the TV failed after that.
                    Section 6 in the service manual talks about power and no screen,...
                    10-30-2024, 10:09 AM
                  • nobbnobb1
                    Panasonic TC-P50U50 Powers Off - 8 blinks
                    by nobbnobb1
                    I have a Panasonic TC-P50U50 plasma TV which powers on briefly, then powers off and flashes the power light with 8 blinks. This TV is infamous for this, of which the suggestion that the SS board has failed due to loose grounding screws and requires a replacement of the following components on the SS board:
                    2x DG302 (Q16051)
                    2x RF2001 (D16041)
                    2x 5.6 ohm SMD resistor
                    1x BD8694 IC
                    I have already gone ahead and replaced these components, as well as cleaning off the ground connections on the SS board as well as the associated...
                    03-21-2023, 08:33 PM
                  • BigPete
                    Panasonic Heatpump Dryer Repair
                    by BigPete
                    I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                    The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                    In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                    Unfortunately the whole machine has to come apart to fix it.
                    I have...
                    11-01-2025, 06:40 PM
