LG 60PZ550 Plasma - No Sound, No Picture
  • southbound
    • Sep 2013
    • 21
    My LG plasma died out without warning the other night while my daughter was watching it. She wasn't standing very close to it at the time, but said she didn't hear anything unusual.
    I can turn it on and the power indicator (front panel) responds, the relay clicks once, but there is no sound or picture. I see no change in the screen at any point (no glow). With the rear cover off and the TV 'on', I see a diode (D1) on the Control board flashing two long, then two short, if that helps any. The Va & Vs test points on the Power board (to chassis ground) both look fine to me {Va:55 = 54.9v , Vs:201 = 201.6v}.
    Any advice on where to go from here? I've worked with some electronics in the past, but am new to TV's. I'm sure I can take whatever readings are needed, but might need clarification along the way.
    That being said, I have what is probably a silly question regarding checking the fuses on my boards. I am not familiar with the way these fuses are mounted to the board. How do you remove them? I'll attach a picture showing what I am seeing.
    Thank you.
  • R_J
    • 9540
    Re: LG 60PZ550 Plasma - No Sound, No Picture
    Those fuses are soldered into the board, check them with your meter, should be close to 0 ohms
    • southbound
      • Sep 2013
      • 21
      Ah, they don't make it easy eh?
      I checked all fuses I see and each was good.
      • southbound
        • Sep 2013
        • 21
        So based on the behavior I am seeing, are there any suggestions on what I should check? Thanks.
          Can you post a picture of the Y-sustain and Z-sustain boards?
          • southbound
            • Sep 2013
            • 21
            Sure. Here are some cell phone pics. If you want more detail, let me know and I'll post clearer ones. Thanks.
              OK, on the Y-sustain, there should be some points or components marked Vsc and -Vy, do you see these? They may look similar to the "Vzb" marking on the Z-sustain in the top right corner.
              • southbound
                • Sep 2013
                • 21
                I see them.
                  OK, can you measure the voltages across those points?
                  Multimeter on DC 1000V, red on (+) marked, black on (-) marked.
                  • southbound
                    • Sep 2013
                    • 21
                    The readings on the Y-sustain look good: Vsc = 150.4v , Vy = -178.3v
                    {tag calls for 150v & 178v, respectively}
                    I didn't know if you wanted me to check the Vzb on the Z-sustain board, but I did and when the set powers on it will climb up to ~6v then slowly bleed down.
                      It looks like from your Vzb reading the Z-sustain is failed then.
                      • southbound
                        • Sep 2013
                        • 21
                        Thank you for your help, Tom. It looks like we are getting somewhere. My next questions are:
                        1. Is the Vzb dependent on anything off the Z-sustain board that should be checked?
                        2. Is this something that can, with a little guidance, be traced further to the component level, or is it more practical to just replace the board?
                        If a board change is needed, any recommended sources?
                        • southbound
                          • Sep 2013
                          • 21
                          I've ordered another Z-sus board. I'll report back with the results.
                            Sorry, I missed your previous post. Hope the swap fixes it. As for causes, I'd be thinking that there's a short on the Z-sustain dragging the Vzb down with it. Possibly the SUS-DN FET/IGBT shorted. Repairable, but will cost at least $20~$30 in parts plus time to diagnose.
                            • Fletch
                              • Sep 2013
                              • 16
                              Is there a viable test for LG plasma buffer boards?
                                Yes but only if you post in your own thread.
                                • southbound
                                  • Sep 2013
                                  • 21
                                  I know that when ordering a replacement, I should look to get the same Rev #.
                                  When I was shopping around for a replacement Z-Sustain board, the EAX62076601 rev G boards were going for $50 and up. I came across one at indyoutletcenter.com for only $2, but it didn't show the revision. Since it was less than $10 delivered, I took a chance and ordered it. It just arrived and is Rev H whereas my original is Rev G. Do you think it's safe to try this one or is there a risk of damage and should just order the same rev board?
                                  Thanks.
                                    Do you notice any substantial layout or connector differences? How about a comparison photo?
                                    • southbound
                                      • Sep 2013
                                      • 21
                                      No differences that I have picked up. Here are some comparison pics.
                                        That should work fine. If one of the inductors (copper coils) or large capacitors were missing, it might have been for a 42", for example, which would not work well. But it looks identical to me, so it's probably some minor revision like changing a component supplier to reduce costs.
                                        • KYBOSH
                                          Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                          by KYBOSH
                                          Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                          No picture but you hear the TV static (white noise) playing loud and clear.
                                          The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                          But it seems they didn't get too far and just left it.
                                          When I first took a look I was amazed at how pristine the inside looked.
                                          Its as if the TV had been in a time capsule.
                                          Caps looked like they were just pulled off the self.
                                          Copper coils had no sign of corrosion on...
                                          02-01-2023, 11:10 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
