Panasonic TC-P50G10 Plasma No Picture, Red Indicator Only
  • PohTayToez
    • Jun 2010
    • 80
    This plasma TV shows no activity other than the red indicator light that comes on when you press power. If you hold power down for a few seconds then the light will go off.
    I've tried all the fuses on the power board and they test good. I've yet to find any other fuses other than a couple on the buffer boards that tested good.
    I've tried disconnecting the buffer boards and shorting SC50 as described in this post. which did not result in a blink error.
    The only thing that I've been able to do that resulted in a blink code was disconnecting the SC board which gave me a 7 blink error which I believe is to be expected.
    Voltages almost all seem off. I'm getting less than one volt going to to SS and SC board and it seems to fluctuate a bit (will start low when TV first gets power and will slowly climb to around .5V)
    I'm getting the following voltages going to the input board:
    0.58v
    5.16v
    2.82v
    14.56v
    0.07v
    I've got pictures of the boards if that helps and I've attached the service manual and a quick guide to the model.
    Service Manual
    Re: Panasonic TC-P50G10 Plasma No Picture, Red Indicator Only
    When you plug it in, are any relay clicks heard?
    • tw2005
      • Oct 2011
      • 6458
      I'm thinking there's a dead short on the SC board if you've gone from no fault code , no startup to a 7 blink with the SC removed so A board is probably ok. You've measure the vsus ( I assume) to the SS/SC at zero so with the SC removed if you measure Vsus again from the PSu I'm expecting Vsus to be normal until the 7 blink cutout.
      Could also measure resistance across SC2 terminals and see if shorted.
      • cloo
        Panasonic ZT60 plasma tv with strange behavior and 8 blink code
        by cloo
        I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
        It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
        So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
        After doing a factory reset this problem was gone and the picture was back to...
        01-06-2025, 06:02 AM
      • rmacintosh
        Panasonic Plasma repair - TH-P60GT50 - Dead, 3 blink code
        by rmacintosh
        I aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
        The symptoms of the tv ar as follows:
        • Plug AC in to back of TV
        • After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
        • The 3 blink code is given by the power LED
        • If the TV is unplugged and then
        03-14-2020, 12:24 AM
      • jm1234
        Panasonic plasma TX-P42ST50 - 6 blinks
        by jm1234
        anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
        It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
        I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
        I checked that board for any obvious faults...
        05-22-2024, 06:59 AM
      • orbit417
        Panasonic Plasma tc-p55vt50 6 blink error code
        by orbit417
        Hi All,
        Thank you in advance for your advice.
        I have a Panasonic Plasma tc-p55vt50 that's about 9 years old and has just recently stopped working :-(
        I noticed that when I turn the tv on I hear a click then screen comes on for like half a second then shuts off and the led blinks 6 times.
        I did some googling and found several video's on trouble shooting all sorts of blink codes. I finally came across one that showed 6 blink error code but for a different model. It recommended disconnecting the SC board to determine if it was the A board or power...
        04-14-2021, 09:11 AM
      • stecos
        Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
        by stecos
        Hi everyone!
        I happened several times, in the search for help from the web, to consult this very interesting forum.
        So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
        Having said that I come to the gist of my post on the forum as the title suggests.
        For my passion for technology I'm now collecting several...
        11-28-2022, 11:39 AM
