hi guys just picked another freebie up a SANYO CE26LD81-B problem seems to be when powered on the screen is a weird white grey color seems some funny colored small dots on top of lcd and some lines going across the screen no side button functions seem to work either for a short while if left on after a while the picture is very good is this a sign of bad caps or a faulty lcd. will upload pics when i have left it a while to show in fault condition and working condition.
Sanyo ce26ld81-b
Tags: None
Re: Sanyo ce26ld81-b
See here. Tab bonds.
Picked this one up off the curb.
http://www.youtube.com/watch?v=mMo3N...ature=youtu.bePlease do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
cheers tom a question the side buttons dont work as child lock is on!! i have found a 24c64wp eeprom on main board can i do a reset will it clear the child lock? is it pins 7/8 and whats the procedure as i dont have original remote only uni one to turn on and off.Comment
Grab 99p store universal remote and program with Philips TV code, or use any Philips remote. Philips codes same as Vestel for some reason.
Then 4725 Menu or Menu 4725 to access service menu and do reset.
If all else fails you will need to replace EEPROM (a blank one works) but try to avoid that if possible as you will have to set up all panel settings and input settings which is a pain in the behind. 5-6 pin jump doesn't normally work on Vestels.Last edited by tom66; 09-11-2013, 09:05 AM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
If all else fails you will need to replace EEPROM (a blank one works) but try to avoid that if possible as you will have to set up all panel settings and input settings which is a pain in the behind. 5-6 pin jump doesn't normally work on Vestels.Comment
a question guys i have connected this faulty tv to my good working lcd tv via scart the faulty screen image is now showing on my good lcd tv does this mean its not the screen after all as may be the main board of the faulty set?Comment
Does the fault that my TV exhibited in the video match your TV?
SCART-ing out really only passes the input signal to the output -- it's not supposed to copy what is exactly on the screen like the menus.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
not really no the symptoms are dark grey blocked screen analogue snow freezes on screen timer freezes lines go across the top third of the screen flashing of and on then if you turn the set off and back on picture is fineComment
Can you get a picture of the problem? Tried gently flexing the TV to see if the problem goes away?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by karatzdiHello,
I know some might say... just buy another one. Sell it as parts..!
So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
Spent some time downloading the Service...-
06-11-2024, 08:38 AM -
by CoinCoin88Hello everyone,
I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver... -
by Pinky DeepakI have a M60-C3 where the left edge has started showing issues as seen in the picture attached. Along with this, I also noticed some darkening on the left half of the screen which went away after I left the TV unplugged. i initially thought it was the led backlight that was wearing out but looks like something to do w the TCONN board. I searched this forum but couldn't find anyone else seeing this issue. most of them were LH/RH completely gone. any insights or guidance is appreciated.
Here's a video of both the issues: https://youtu.be/hMqc760nB3o1 Photo -
Trying to work out if this is TFT problem or TCon issue.
The TV powers up but the top half of the screen, from the right it is OK, but as you look across to the left halfway across it starts get duller and duller until it is very dark on the lefthand side, currently I trying to clean the remote as it seems to have something film wise on the pads stopping it from registering buttons pressed.
Also when changing the screen size of Windows PC display to say to a smaller pixel sizewindow, the original window displayin the top left stays/takes a few seconds to disappear?...2 Photos -
by jacky.xueHi everyoneone:
My lenova note book after power button press, it blink 12 times in white led, check attached video ~
have anybody see this condition?
Before i try flash bios 8M&16MB , it ok, but maybe i didn't backup (read) these flash raw data,
after i write backup 8&16 MB image to laptop again ~ it become this conditions now ,
I don't know if 8M or 16M image is incorrect ~ could somebody have this kind of condition can give me some idea ?
I am sorry, my english is not well ...
Might be write corrupt bios back to note book....-
Channel: BIOS Requests ONLY!
- Loading...
