Sanyo ce26ld81-b
    Sanyo ce26ld81-b
    hi guys just picked another freebie up a SANYO CE26LD81-B problem seems to be when powered on the screen is a weird white grey color seems some funny colored small dots on top of lcd and some lines going across the screen no side button functions seem to work either for a short while if left on after a while the picture is very good is this a sign of bad caps or a faulty lcd. will upload pics when i have left it a while to show in fault condition and working condition.
    Re: Sanyo ce26ld81-b
    See here. Tab bonds.
    Picked this one up off the curb.
    http://www.youtube.com/watch?v=mMo3N...ature=youtu.be
      cheers tom a question the side buttons dont work as child lock is on!! i have found a 24c64wp eeprom on main board can i do a reset will it clear the child lock? is it pins 7/8 and whats the procedure as i dont have original remote only uni one to turn on and off.
        Grab 99p store universal remote and program with Philips TV code, or use any Philips remote. Philips codes same as Vestel for some reason.
        Then 4725 Menu or Menu 4725 to access service menu and do reset.
        If all else fails you will need to replace EEPROM (a blank one works) but try to avoid that if possible as you will have to set up all panel settings and input settings which is a pain in the behind. 5-6 pin jump doesn't normally work on Vestels.
          i can get into the service mode no problem at all but cant scroll down the menu at all thats the remote i used a 99p one turns on off etc volume etc all works wont scroll down menu thats also why i cant turn child lock off i can get to it in the menu but not scroll down to highlight it to turn off!!
            May have to swap the EEPROM then.
              a question guys i have connected this faulty tv to my good working lcd tv via scart the faulty screen image is now showing on my good lcd tv does this mean its not the screen after all as may be the main board of the faulty set?
                Does the fault that my TV exhibited in the video match your TV?
                SCART-ing out really only passes the input signal to the output -- it's not supposed to copy what is exactly on the screen like the menus.
                  not really no the symptoms are dark grey blocked screen analogue snow freezes on screen timer freezes lines go across the top third of the screen flashing of and on then if you turn the set off and back on picture is fine
                    Can you get a picture of the problem? Tried gently flexing the TV to see if the problem goes away?
