6HA0136911 main board Insignia NS-LCD32
  • Tvbob
    tvbob
    • 204
    Hello, How could one get into the factory menu of an insignia NS-LCD32 with an 6ha0136911 main board. I want to try to change panel settings, an schematic would be nice too. thanks
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: 6HA0136911 main board Insignia NS-LCD32
    try 2580 you may need another code to get into advanced menu though 0000 might work only a guess
    http://www.toms-service-manuals.com/...&Search=Submit
    • ygorsan
      by ygorsan
      🧩 Problem Summary:
      • I
      07-28-2025, 08:34 AM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • JDC
      by JDC
      ONN 100012588
      Long answer:
      07-15-2022, 07:39 AM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • cheeky2
      by cheeky2
      05-25-2024, 03:27 AM
