Panasonic TC-L47E5 LED TV blinking red power light PLEASE HELP
Re: Panasonic TC-L47E5 LED TV blinking red power light PLEASE HELP
C1, the yellow capacitor 470uF/35V. Test on continuity range. What do you see? It should briefly show a low number and beep, but go to OL after a few seconds.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Yes.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
The payless LED driver board acts as you say it should. But my original LED driver noes notComment
Not shorted, then. You can try jumpering the fuse on the P board. This should be OK for a quick test as the LED driver is fused. If the fuse on the LED driver blows, or the P board shuts down (power cycling, etc.), you know that the LED driver has an issue. Otherwise the backlight should come on and the TV should work.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Saw your other post... perhaps try jumpering fuse on old P board with new LED driver?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I'm confused I don't know why both LED driver boards on the yellow cap gives me different results.
Can it be because one is charged and the other one is not?Comment
It may be faulty. It could have caused the fuse on the original power board to fail (fuse blown.)Last edited by tom66; 10-19-2013, 03:46 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Fuse is PA7401.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Great!
Now replace the original fuse on the P board for long term reliability and safety. This should work:
http://www.digikey.com/product-detai...2-1-ND/1473444
Return your new P board as defective and keep the old failed LED driver as a spare for extracting parts maybe.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Can I pull that fuse from another board? Also what does this all mean? what was faulty from the start? was it the LED driver board? or the PS? or both at the same time?Great! Now replace the original fuse on the P board for long term reliability and safety. This should work:
http://www.digikey.com/product-detai...2-1-ND/1473444Comment
Looks like your LED driver failed. The fuse on it is rated 6.3A. It shorted the power supply, causing it to output a large current. The power board fuse failed first, probably just random which one fails.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Ok, so my original LED driver board is faulty?
So you think that the original LED driver failed causing the power supply to fail as well correct?Last edited by sfernandes; 10-19-2013, 04:03 PM.Comment
Yes, I think that's what happened. Either that or the fuse failed randomly, but that doesn't explain the differing measurements between LED drivers.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Ok, it would be nice if I can get that fuse from another board so I wont have to wait. When looking for it on another board what do I look for is it the markings that it has on it that have to match?Comment
You can use the TV as is, but you should replace the fuse ASAP. Markings would be similar to the white fuse on the LED driver marked 6.3A.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by SLB007I get no image nor backlight, standby light blinks 13 times then stops. Any clues what it could be no evidence of damaged components11-02-2025, 04:08 PM
by clooI recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
After doing a factory reset this problem was gone and the picture was back to...01-06-2025, 06:02 AM -
by ItepKHey everyone!
I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
This post describes my entire troubleshooting process of this TV.
When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
I've taken the unit apart, and I've started to check some voltages:
- On the P11 connector, there is 15V DC only for a brief moment, then it goes
by YasaChHello...
my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
i opened the back cover no sign of damage on the powery suply or motherboard
when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites2 Photos -
by VebririonHi everyone,
I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report... - Loading...
