Vizio GV46L Blue screen.
+ More Options
Posts
  • truep
    • Aug 2010
    • 373
    Got a chance to pick this up cheap. Has a solid blue screen. Don't know about audio.
    Main or TCON?
  • Glitcher
    • Mar 2013
    • 673
    • USa
    Re: Vizio GV46L Blue screen.
    I remember this vizio start up with a blue screen with the "no signal" message if there's no input. I'm guessing if its just a blue screen with no message its a main board problem and something is corrupted in it.
    • spice_disc
      Vizio TV M50-C1 reboot cycle and static on screen
      by spice_disc
      I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
      The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
      09-08-2024, 02:37 PM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • slimmy182
      Need HELP troubleshooting solid Blue screen Nintendo Switch BSOD
      by slimmy182
      I recently got a switch which did not turn on (blu screen and could not do anything). It draws 15v so battery is charging as normal. I opened it, it's never been touched by anyone, rose old thermal paste still there and foam attached to the heat sync. On microscope I did not see any sign of corrosion or any particular damaged components, only dust. Completely cleaned the board with isopropyl alcohol and give a try with no luck. I cannot exclude that this consol had not being dropped to the ground since it has a sing on external enclosure. Anyway detaching the eMMC screen did not light up and enter...
      03-22-2022, 05:04 AM
    • ulthi
      Samsung QE50Q60TAU - Flashes black/blue screen
      by ulthi
      My tv is not able to turn on. I flashes between black and vague blue screen (see video)
      I have tried different resets and have also replaced the main board - but nothin has changed.
      Any suggestions?
      https://youtu.be/acYQ-ImmhWA
      10-14-2025, 01:48 PM
