insignia ns- pdp32-09 no power
  • CR Designs
    • Dec 2012
    • 430
    Hello, picked this up a why back. first time working on a plasma, This tv is dead no power . checked voltage on PSU get no readings at all. fuses all check out to be good.unplugged every thing on PSU no voltage.also caps look good. hope you can help.
    Re: insignia ns- pdp32-09 no power
    Check standby diode. Check any fusible resistors.
    • CR Designs
      • Dec 2012
      • 430
      I had checked all the diodes they were good. To make sure which one is standby diode ?
        It will be near the standby transformer, which is the smallest one on the board.
        • CR Designs
          • Dec 2012
          • 430
          Standby dicde read .1 one way and .378 the other way
          • CR Designs
            • Dec 2012
            • 430
            These 2 resistors read .1 both ways see picture they are circled
              OK, check voltage across the small (<100uF <50V) capacitors on the primary side of the power supply. Something is going to be missing.
              • CR Designs
                • Dec 2012
                • 430
                I found 3 of them all read .0 volts
                  OK, can you get a whole or split pictures of the top and bottom of the power board?
                  • CR Designs
                    • Dec 2012
                    • 430
                    I checked the small caps again 3 of them were testing at 0.01 and 0.02. the forth one tested 0.00
                    • CR Designs
                      • Dec 2012
                      • 430
                      Here's pictures of power board
                        For future reference, bottom refers to the other side of the PCB. Can you get one of the other side?
                        • CR Designs
                          • Dec 2012
                          • 430
                          Here's pictures of bottom
                            Part # of this chip please.
                            • CR Designs
                              • Dec 2012
                              • 430
                              part number is :
                              1207A
                              PFMO
                                OK, check resistance between pins 4 and 6.
                                • CR Designs
                                  • Dec 2012
                                  • 430
                                  How are you numbering pins ?
                                  1 8
                                  2 7
                                  3 6
                                  4 5
                                    Refer to datasheet
                                    • CR Designs
                                      • Dec 2012
                                      • 430
                                      Read pin 4 pin t0 6 pin = .1
                                        0.1 ohms, or single "1" meaning infinite/over-range?
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                          09-06-2024, 05:59 AM
                                          HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 02:15 PM
