insignia ns- pdp32-09 no power
    Hello, picked this up a why back. first time working on a plasma, This tv is dead no power . checked voltage on PSU get no readings at all. fuses all check out to be good.unplugged every thing on PSU no voltage.also caps look good. hope you can help.
    Re: insignia ns- pdp32-09 no power
    Check standby diode. Check any fusible resistors.
      I had checked all the diodes they were good. To make sure which one is standby diode ?
        It will be near the standby transformer, which is the smallest one on the board.
          Standby dicde read .1 one way and .378 the other way
            These 2 resistors read .1 both ways see picture they are circled
              OK, check voltage across the small (<100uF <50V) capacitors on the primary side of the power supply. Something is going to be missing.
                I found 3 of them all read .0 volts
                  OK, can you get a whole or split pictures of the top and bottom of the power board?
                    I checked the small caps again 3 of them were testing at 0.01 and 0.02. the forth one tested 0.00
                      Here's pictures of power board
                        For future reference, bottom refers to the other side of the PCB. Can you get one of the other side?
                          Here's pictures of bottom
                            Part # of this chip please.
                              part number is :
                              1207A
                              PFMO
                                OK, check resistance between pins 4 and 6.
                                  How are you numbering pins ?
                                  1 8
                                  2 7
                                  3 6
                                  4 5
                                    Refer to datasheet
                                      Read pin 4 pin t0 6 pin = .1
                                        0.1 ohms, or single "1" meaning infinite/over-range?
