insignia ns- pdp32-09 no power
Re: insignia ns- pdp32-09 no power
Check the soldering for your replacement fuse.
The capacitor near the NCP1207B IC, did you measure that previously as being nearly 0V?
OK, different tact: what voltage, on DC 600V or higher, do you read across the outer two pins of the bridge rectifier?
Hard to be certain, but I am thinking the NCP1207B is bad. If you have high voltage coming into the board, but there is no Vcc, the NCP1207B is bad.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Originally posted by tom66 View PostCheck the soldering for your replacement fuse.
2 pins on bridge rectifier 100v and 55v
Across the outer two pins of the bridge what do you see, red one end, black other end?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Good. OK, I say replace the NCP IC and go from there.
Digikey sell them
http://www.digikey.com/product-detai...SCT-ND/3462388
I would order some caps to recap this unit as well, even if the capacitors aren't bad it's from the same generation as a lot of bad LG capacitor problems.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Originally posted by tom66 View PostGood. OK, I say replace the NCP IC and go from there.
Digikey sell them
