Any idea where I can get replacement flat flex cable from?
  • SuperSkippy
    • Nov 2012
    • 58
    I've got this TV (it's a Samsung LE-37A557P2F) and the flat flex cable that goes between the T-Con and the panel has been chewed and the contacts have been lifted. Has anyone got an idea where I could get a replacement cable from? The flat flex has 80 pins with 0.5mm pitch.
    Anyone got any experience with trying to get flat flex cable?
  • jose6326
    • May 2013
    • 707
    Re: Any idea where I can get replacement flat flex cable from?
    did you try ebay?
    • SuperSkippy
      • Nov 2012
      • 58
      Originally posted by jose6326
      did you try ebay?
      Well yes. But here's the thing. Most similar flat flex cables on eBay are advertised as "coming from TV model X". Or worse, coming from Panel type Y. And even worse, a lot of the eBay sellers (I guess they obtain smashed screens, and strip the boards out) don't see these cables as having any value and discard them.
      I haven't got time to wait for someone to a) buy a smashed version of the TV I have, b) with the right panel model, c) strip it for bits, d) decide that these cables are worth keeping and e) list it on eBay.
      Put another way, if I'd lost the cable between the PSU and the main board say, I'd be able to find in short order that it was say a 20 pin connector, with 1mm pitch, in two rows. Then I'd be able to buy a replacement cable, or buy the connectors and crimp up a replacement cable myself. I wouldn't have to wait for someone to list "PSU cable from TV model X" on eBay, and then try and rinse me for £30.
      So what I'm really asking is "Is buying generic flat flex cable a thing, and if it is, what do I need to know to buy it?"
      Otherwise I'm going to have to strip the TV for parts, which seems a shame since I reckon it would be OK with a brand new cable.
      • jose6326
        • May 2013
        • 707
        gotcha
        this might help but not sure if they ship to your location
        http://www.digikey.com/product-searc...k=flex%20cable
        • Ltank
          • Jun 2013
          • 776
          tvpartsguy has flat flex cables
            Is there BN-XXXX number printed on the cable?
            • SuperSkippy
              • Nov 2012
              • 58
              Bump!
              Time I did something with this TV, I think.
              Here are photos of the chewed flat flex I've got:
              The problem I've found is that I can't get 80 pin flat flex from anywhere (e.g. Digikey). 60pin is no problem.
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
              • Prott
                Soldering flex cable - tips & tricks
                by Prott
                Hello fellow badcappers,
                I have to solder a MacBook (A1708) screen flex - one of the two data flexes got slightly torn (2 broken traces). I've seen some videos on youtube where people scrub the coating and then simply apply flux and solder to the exposed copper traces (and then run a jumper wire). However no matter what I try the copper does not take the solder at all - the more flux I add the more it actually stays only on the iron itself.
                I am practicing on a spare flex cable and it's gettiing quite annoying - to a point I am actually thinking I have to be doing something...
                10-04-2023, 06:25 AM
              • lcdcaps1
                A1229, Flat / Flex Cable 821-0511-A repair
                by lcdcaps1
                Hi
                I am trying to repair the above flat / flex cable for an A1229 machine
                I cant see where the traces are coming from
                I have attached photo of the cable taken from online and highlighted the pins I need to solder a jumper wire to and then mask but cant see where the traces are for the side where the pads have been ripped
                Look forward to the help, again
                Many Thanks...
                10-02-2020, 05:29 AM
                Lenovo IdeaPad Flex 5 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
                This specification for the Lenovo IdeaPad Flex 5 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 boardview and Flex 5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                09-07-2024, 07:20 AM
                09-07-2024, 06:38 AM
