samsung LN40c530F1F wont turn on
  • beano
    • Aug 2013
    • 9
    • usa
    I plug tv in the red light goes on, I hit the power button it blinks 5 time then turn off
    I checked the cap on the ps they look ok, I unplug connector going to main pwb the black light goes on please help im stuck!!!!!!!!!
  • capkid
    • Oct 2010
    • 1339
    Re: samsung LN40c530F1F wont turn on
    It sounds like your main board is bad. Can you post pics of the circuit board layout? From what I can tell by looking at pics of power supplies for this TV, the inverter transformers live on the power supply. This would further point to a problem with the main board being likely.
    Edit: Can you clarify what you mean by "main pwb"? I took your statement to mean that you disconnected the "main board", which is the board that has all the A/V inputs, from the power supply.
    LG Plasma Mal-Discharge Correction Service
    • beano
      • Aug 2013
      • 9
      • usa
      Yes the 1 with the a/v inputs I will take pic tomm
        Try disconnecting the cable to the T-CON board, but I believe it is the problem on the main board.
        • gamethriller
          • Oct 2014
          • 153
          Old problem here. Have the same problem, if I unplug the t-con there is no change. But if I unplug the main the back light and tv turns on.....So my guess would be main....Is there a way to further test the main?
          • ryanleeis
            • Dec 2011
            I have this same problem. did you ever find out if it was a main board problem or the power supply?
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Have you done what was in post #5 and what were the results?
              • PNI E.
                Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                by PNI E.
                Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                03-17-2025, 04:23 AM
                09-07-2024, 05:50 AM
              • Asraf Atb
                Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                by Asraf Atb
                Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                01-27-2025, 05:02 PM
              • Yanleb
                Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
                by Yanleb
                Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
                If they are not compatible why did Samsung give them the same part number to begin with?
                08-04-2025, 11:35 PM
              • elpatxi_bcn
                Samsung HG75EJ690UB Hotel TV, change main?
                by elpatxi_bcn
                Hello!
                I just got a Samsung TV model HG75EJ690UB 75" and 4K. It is a hotel TV, with a slightly different version of the Tizen operating system than the TVs at home.
                Being a hotel, it is covered in many functions. With the service menu I can unlock some, but not others. For example, I can't install apps like Netflix etc...
                The fact is that it seems that I can replace the main by a, say, "normal". I think the one that corresponds is NU7105, ref BN94-02635. At work, which is a convention center and a hotel, I have many TVs from 55" to 85" that...
                05-19-2023, 03:21 AM
