Samsung Ln40a650a1f image flicker/ghosting
  • topfli8979
    • Oct 2012
    • 311
    Samsung LN40a650a1f, picked up off curb today.
    Tv powered on great,good picture for about 10 minutes. Then whole screen starts ghosting through the images, and left half of screen starts to jump/flicker especially with any word images. Checked all boards for visual inspection, good there. Remove/clean/reseated lvds,ribbons on t-con board to no avail. Bad panel?
    Re: Samsung Ln40a650a1f image flicker/ghosting
    Tab bonds, very common on this model.
    • topfli8979
      • Oct 2012
      • 311
      Update: I found 2- tab bonds that were loosing connection, I put some thermal compound pad I bought off ebay between the ribbons and the frame. Works great, tv has been working great for 24hrs now. No more flicker.
      • truep
        • Aug 2010
        • 373
        I have used those thermal pads too! they seem to work better than plain plastic or rubber. Had a sony I used for 2 years as a main TV and it was still working fine when I gave it to my son.
        • Tiezane
          • Aug 2013
          • 98
          Someone just left it sitting on the curb? lol. Was this a pickup from Craigslist, or were you just lucky enough to be driving past and find it? Why can't I ever find those deals? Nice find!
          • topfli8979
            • Oct 2012
            • 311
            Yep, found by someones trash can. I have found/purchased about 30 tv's off craigslist. Only problem now is people are figuring out that they are repairable, and they are getting harder to find. Good Luck!!
            • Tiezane
              • Aug 2013
              • 98
              I've managed to pick up a few good finds so far, I made the unfortunate mistake of paying $20 for a 42" with a cracked screen, but I figure it will still be good for the boards. I've spent about $95 and picked up a 32" samsung that was covered under their capacitor settlement, a 42" maxent plasma, a Samsung LN40B650, and a Dell W2600. I also had someone give me a 42" Panasonic plasma, but unfortunately it has a cracked screen as well. I want to find some stuff just sitting on the curb though.. I must live in the wrong area
                09-07-2024, 05:50 AM
              • fixit007
                Samsung flicker - BN44-00932T board or else?
                by fixit007
                I picked up this TV that the prior owner said - just died.
                Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
                Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
                Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
                05-04-2024, 06:14 PM
              • shlomim412
                samsung ua55es6800 - no image
                by shlomim412
                hi
                having problem with samsung ua55es6800
                tv had backlight on, sound working - responds to the remote control but no image.
                check tcon board - had 12v in but no other voltages present.
                when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
                when leaving only left side connected - again no voltages and no image.
                put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
                kept trying to block less pins on the left ribbon cable...
                05-15-2024, 05:00 AM
                09-06-2024, 11:40 PM
