Philips th-42pv70p plasma tv problem
  • anno
    • Sep 2007
    • 140
    • netherlands
    Hi.
    I have a 42 inch panasonic plasma tv , model th-42pv70p with a problem.
    after the tv has been on for 30-45 minutes the picture is getting 'green'.
    Best is to show some pictures, i don`t know how to describe it.
    some contours are still visible. anyone knows what can be the problem?
    Re: Philips th-42pv70p plasma tv problem
    There is a cable running from the "A" board, which has the video inputs on it, going to the "D" board which processes this image. The "D" board is underneath the "A" board. Reseat this cable (remove and re-insert both ends) and see if this fixes the issue.
    • anno
      • Sep 2007
      • 140
      • netherlands
      ok thanks. i will check that
      • anno
        • Sep 2007
        • 140
        • netherlands
        i don`t see the A board. There are 2 boards called H and DG .
        the H board has speaker out,sound processor, AV terminal, AV switch.
        THe DG board has Digital signal processor, micon, HDMI interface, peaks lite 2.
        I see the D Board, it's underneath this boards (H and DG boards). I think you mean this boards?
          On this set, DG to D board; it's an older model the newer ones have DG+H in one A board,.
          • anno
            • Sep 2007
            • 140
            • netherlands
            I reseated this cable, i think the problem is fixed now. The fault didn't came back yet
            thanks
              Glad to hear! So common on these models (PZ70/PZ80 too!)
              • theone111
                by theone111
                3. Problem: TV shuts down
                07-22-2024, 10:36 AM
              • janos6662000
                Philips 47PFS7509/12 LCD TV problem
                by janos6662000
                Hi
                I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                When i applied cable signal to check image, i had normal picture, but TV was restarting.
                I downloaded original firmware and applied the update, but the problem remained.
                From a colleague i received a "factory package software" which is a lot bigger.
                I made another firmware update, but still did not solve the problem.
                Somewhere on the way the error got worse, because at the moment the...
                08-12-2025, 12:54 PM
              • courtcircuit
                Philips HTS8000 home cinema noise problem
                by courtcircuit
                Hello
                I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                Removed each of tyhe boards
                02-08-2025, 08:22 AM
              • celiabrown
                Issue with Plasma Philips 37inch chassis FTL2.1
                by celiabrown
                Hello guys,
                My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
                Can someone has any symptom like this ?
                Thanks​
                05-09-2024, 10:56 PM
              • bohaboha
                PHILIPS 32pfl3403d Flat-panel TV Upgrade Assistant problem
                by bohaboha
                Hi trying to update my Philips cause in retail mode not possible to get out from it i get this message in update site : Error message: no data exception. Your reference: Request ID (server_1930105)
                how to fix it thanks
                02-05-2025, 09:23 PM
