Vizio VO320E Bad Power Supply Board?
  • alja
    DIY Junky
    • Aug 2013
    • 47
    Re: Vizio VO320E Bad Power Supply Board?
    Thank very much Tom, I really appreciate your time and patience, I will post results once I get the new one in.
    Again,
    • alja
      DIY Junky
      • Aug 2013
      • 47
      I just pulled out the diode and the reference is MUR460 / 937 but I cannot find the 937 is there any way to replace it how can I choose the correct one?
      And off course you were right, after pulling out the diode I test the other one and gave me 425
      • Caleb
        Smokin IC's
        • Feb 2013
        • 645
        I think you just need the first portion MUR460. Datasheet attached below
        Liberating magic smoke one part at a time
        • alja
          DIY Junky
          • Aug 2013
          • 47
          Thanks Caleb, you are right I found that the second number has to do with the manufactured date. Ordering ......;-)
          • alja
            DIY Junky
            • Aug 2013
            • 47
            Just for reference...., I got the diode, replaced it and is working good!
            thanks
              Fantastic to hear! Thanks for the feedback.
              • Ashroyer05
                • Sep 2013
                • 162
                • U.S
                #47
                It's cool to see this posting. I have the same problem with my vizio vl320m. I went over the power supply the other night and found a bad diode, the same one under the heat sink. I will order and hopefully I will get the expected voltages. I found that before seeing this posting, but this posting serves as a confirmation. This site is a great tool!
                • inflitedan
                  InfliteDan
                  • Oct 2013
                  I also have this same Vizio VO320E power supply (DPS-172EP) that has me a bit stumped. No output on any rails. Not even on the +5vSB. Main fuse is good. All caps are good. Initially, I found 2 bad MOSFET’s (Q700 & Q708) I replaced them and still no power anywhere. I followed this post up to #28. As suggested I checked the DC voltage across C802, it’s 180vdc. Reading on to post #30, the voltage across C903 is alternating between 9 and 13vdc. Post #36… Diodes D802 & D803 seem to be OK. Thoughts?
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • howardc64
                    by howardc64
                    07-24-2025, 05:17 PM
                  • Hakuu
                    by Hakuu
                    Hi There,
                    More Details
                    TV Model - LG OLED77G1PUA
                    07-12-2023, 02:37 PM
                  • canadaboy25
                    Panasonic TC-P54VT25 No image. A or D board?
                    by canadaboy25
                    I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                    I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                    01-17-2021, 01:06 AM
