Reconstruction
  • manstoblame
    • Jan 2011
    • 85
    Reconstruction
    I have this Westinghouse lcd tv sk32h635s initially it had only blue power on button indication nothing else I tested all components on the smps the inverter board t-con and main logic board found bad caps on smps replaced then replaced a couple of low voltage n channel mosfets. Tv powered on everything was good except it started darkening in the one corner and then went black now its back to the same crap I have the 5v the ps-on the 12 and 24 volt outputs. Was the flickering and darkening of the screen because of the backlights going bad? I asked myself so I took apart the cabinet diffuser yada yada and noticed the ccfl bulbs looked dark on the ends and some of the white powder in the tubes was missing near the contacts of the tubes and figured that was the problem. My question is has anyone here at BadCaps has converted the ccfl lighting into a working LED panel that will operate properly with an lcd tv? and if so would you please help me I have put a lot of time in trouble shooting this unit to have it not work now because of the backlight fault. Any help is appreciated wise cracks too
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Reconstruction
    The first symptoms are like this:
    https://www.badcaps.net/forum/showthread.php?t=27768
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • manstoblame
      • Jan 2011
      • 85
      Re: Reconstruction
      thanks Rahja at first glance I thought whats all this crap it has nothing to do with my query then went to the link you'd think having looked over this information before about the transformers i would have double check their solder connections Anyway after re soldering the legs of the transformers everything is working fine thanks alot for the wake up call. this is a great lcdtv just needed attention. Doing nothing but voltage checks with a DMM I pretty proud of myself thanks again. Big BIG Ups to BadCaps and a big one to you too folk!!!!!
      • ttmi100x
        HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
        by ttmi100x
        Greetings everyone,
        I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
        The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
        Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
        Upon closer inspection...
        07-31-2024, 06:36 PM
      • mikey5791
        Help on Samsung Syncmaster T220 dead ccfl lamp
        by mikey5791
        This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
        Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
        10-18-2020, 03:17 AM
      • Topcat
        Nihon Kohden (Tyco Electric) ET2400LM 24" Restoration
        by Topcat
        This was rescued from a recycle gaylord from a hospital along with some other things....
        I don't have to explain the significance of restoring this; 16:10 Aspect Ratio, 1920x1200; very high end Samsung LTM240CT04 panel. Add in it's blonde (will pair nice with a retro rig) and also ELO touchscreen. It is very well made, very heavy. Even used these are hard to find and expensive....but it had some problems...
        Problem one, the external PSU was missing. I found one in my stash that had the correct voltage (12V) with the goofy 4-pin plug it used. It however was light on the...
        08-02-2023, 10:07 PM
        Design of CCFL Backlight Inverters with Frame & Bar Cores
        Summary
        Portable devices, such as notebook computers and personal digital assistants are developed rapidly nowadays, which places an increasing demand on display technology. The LCD with cold cathode fluorescent back lighting satisfies the requirements on display performance, size and efficiency.
        The backlight inverter plays a crucial role in supplying the power to the lamps of these flat-panel displays.
        The frame and bar ferrite cores, described in this brochure, are especially designed...
        10-07-2024, 04:26 AM
      • caseyjay_48
        Sony KDL-46BX450 Inverter Troubleshoot Logic
        by caseyjay_48
        I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
        I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
        09-23-2022, 08:08 PM
